Strange Transfer Issue: Hub Stuck on My Account After Device Transfer
Hey SmartThings Community and ST Team,
I’m hoping someone can help me with a weird transfer issue I ran into recently. I conduct Smart Home activation services, and my standard process is:
  1. Register the SmartThings Hub at my location.
  2. Include and set up all the customer’s devices.
  3. Transfer the Hub and all devices to the owner’s account (using the device trasnfer function).
Issue
I performed an activation for a client, and during the final transfer, something strange happened:
  • I transferred the devices using the device transfer function.
  • The client successfully scanned the code and the app prompted that they “received the device(s).”
  • All of the client’s devices are working perfectly under their new account!
  • BUT, the actual SmartThings Hub is still showing on my SmartThings location/account.
Essentially, the devices transferred, but the Hub itself seems to have been left behind on my account, even though it’s physically at the client’s house and controlling their setup.
I need assistance from the SmartThings Support Team to force the transfer of the Hub (device ID/serial number available upon request) from my account to the owner’s account.
I’m looking for a way to do this without interrupting or requiring a re-setup of all the devices that are currently working for the client. The devices are already linked to the new location, just the “parent” Hub registration is hanging on my end.
Has anyone encountered this specific partial transfer issue before? Any guidance or direct help from an ST staff member would be greatly appreciated!
Thanks in advance!
Tagging @nayelyz @Itati
Hi, @Tengku
So, just to confirm, the hub only appears in your account but not in the client’s account? I’m wondering if there aren’t two Hub instances, one for you and one for the client.
Either way, we need your help to get the following information, please:
  1. Approximate timestamp (date and time including your timezone) on when you performed the transfer, just to have a better reference to look at the logs
  2. Enable support access for both accounts
For you:
For the Client:
  1. If you know the client’s email, please share it with us as well and ask him/her to follow the instructions below
For both:
See more information about this access here: https://support.smartthings.com/hc/en-us/articles/36170233944852-Enabling-Account-Data-Access-for-Support
Hi @nayelyz ,
The hub only appear in my account. Not appear in client account.
Timestamp: 29/5/25 - Between 10am to 12pm. GMT+8.
Support access are enabled. I DMed for client’s email.
Thank you for the information, @Tengku
I created a report for the engineering team, so, once I get their feedback, I’ll let you know.
Hi, @Tengku
The engineering mentioned that the first step to remove the hub from your account is to follow these instructions, so, can you help with this, please?
  1. Go to my.smartthings.com/advanced/hubs
  2. Enter the Hub’s details and find the “Driver Channel” section
  3. Navigate to each channel link in that section and once in the channel page, click on “Unenroll”.
  4. Make sure there are no remaining channels enrolled in the Hub.
Please let us know once you finish or if you have any questions.
Hi @nayelyz,
I have unenrolled every channels in the Hub.
Please proceed.
Hi, @Tengku
Thanks for your patience. The customer should see the hub now on his account, can you confirm that he can see it now, please?
Also, please confirm that you don’t see it as part of your account, it appears as “shared” now since the customer is the owner of the location “My home”
Hi @nayelyz ,
I did not see the hub in the owner account. And the hub still appear in my account. Please advice.
Hi, @Tengku
From our side, we can see the hub is now owned by the customer and it’s present on his location “My Home”, so, just to discard this being related to a cache issue, please follow these steps:
This is for Android users only
  1. Close the SmartThings app
  2. In your mobile device, go to Settings
  3. Go to the App Manager option (where you can configure notifications or other options for each app)
  4. Look for the SmartThings app and enter its details/configuration
  5. Tap on Memory/Storage and click on the option Clear cache
Then, reopen the app for the customer and go to the section of “All devices” and look for the hub there since the transfer made it not assigned to any room.
Finally, remove the “installer” account from the Customer’s location “My Home” as follows:
  1. Go to the home tab
  2. Click the location and go to ‘Manage Locations’
  3. Click the ‘My home’ location
  4. Scroll down to the ‘members’ button and click where it says ‘4 people’
  5. Click the name of the installer
  6. Click ‘remove member’
Hi, @Tengku
I’m following up on this issue. Did the steps mentioned above help you?
Hi @nayelyz ,
The steps above does help me. The hub is now in owner’s location.
Thank you for your help!
