Anyone give me a clue as to what’s going on. The Red and Black twisted pair seem to be hot even with the power off. This is on a bathroom of that helps and the is a gfi wall socket near by.
Thanks for the help.
Have you taken a look at the FAQ. It appears you may have a setup like line-switch-load-switch-1 but it is hard to tell where the wires are going in the main box.
Thank you for giving me a starting point. I missed the FAQ sorry. The light is running on a 3 way that I pictured in my last post. Best as I can tell there are 3 separate 3 wire coming down into the box and a 2 wire up into it. The slave switch just has a 3 wire in the box. I hope this helps explain better what I have.
