Driver reports units mW when the should be Watts. In the screen grab the unit should be kW, so it should be 1kW
What driver you are using?
Se if you have an option to adjust te divisor in the device settings.
you can give a try to the Zigbee switch power MC or open an issue on smartthings Smartthings Edge Driver Github
