There seems to be a limitation on character count for the top level domain of the URL configured when setting up a Cloud Connector SmartThings Schema WebHook Endpoint in the Developer Workspace. I am trying to use my domain that ends in “.solutions” as a URL, but it throws input validation error “Please enter a valid HTTPS URL.” I tested with random characters and the validation will take any combination as long as the TLD is 6 characters or less.
This is preventing me from developing using my existing registered domain. Hopefully this validation criteria is something that the ST back-end server developers can easily update to accept longer TLDs.
Hi, @Freeblazin, I can see what you mean. I was able to enter something like:
https://xxxx.ngrok.io.solutions
But this was rejected:
https://xxxx.solutions
So, I’ll check with the engineering team this situation. Once I get more info, I’ll let you know.
In the meantime, while you develop your integration, you can use:
I just made some tests to change this value from the API (SchemaApps endpoint) and it seems it was effective, can you help me verify this, please?
The request is to https://api.smartthings.com/v1/schema/apps/AppID; the AppID is found in the Developer Workspace, it starts with “viper_...”.
The body of the request would be:
