Schema Devices and Custom Capabilities
Creating custom capabilties for schema devices
Using the SmartThings CLI and Developer Workspace
We are going to create a Cloud Connected Device using Schema and webhooks. Our base device will be a basic switch.
The first part of this tutorial will cover create the connector, oAuth server, and adding the Switch to SmartThings. The second part of the tutorial will cover adding a custom capability to this new device.
Prerequisites:
  • Samsung Account
  • Developer Workspace Access
  • Developer Mode Enabled
  • Glitch Account
  • Text File
Step 1: Remix this Glitch account (connector)
  1. Set the values in the .env file using .env-example as a guide.
  2. Once the remixed app is up and running copy its URL to your text file.
  3. Register the webhook url in SmartThings Developer Workspace and deploy it for testing.
Step 2: Remix this Glitch account (OAuth)
  1. Edit the .env file to set your own client ID and secret, for example:
  EXPECTED_CLIENT_ID="somerandomvalueyouchoose"
  EXPECTED_CLIENT_SECRET="anotherrandomvalueyouchoose"
  AUTH_REQUEST_PATH="/oauth/login"
  ACCESS_TOKEN_REQUEST_PATH="/oauth/token"
Step 3: Run each of your newly remixed apps in their own browser window.
You should now have three browser windows open.
  1. Developer Workspace
  2. Remixed Connector
  3. Remixed oAuth Server
Step 4: Register in the developer workspace
Name your Connector
Click Register App In the Cloud Connector Box
Click Webhook Endpoint
Enter your connector URL
Click Next
Now Move to the oAuth app tab from Step 2.
Create a Client ID and Secret in the .env file
Back in the workspace these are the ID and Secret you will use in the form.
"Client ID" = the client ID you created in step two
"Client Secret" = the client secret you created in step two
"Authorization URI" = your-glitch-project.glitch.me/oauth/login
"Token URI" =  your-glitch-project.glitch.me/oauth/token
Click Next
Edit your catalog entry. NOTE your image must be 240x240px
Click Next
WARNING - You need to copy the values from the screen
Edit the .env file for your connector app, using the copy button from this screen and copy the Client ID and Client Secret to their fields.
Click Go To Project Overview
Click Deploy to Test
Click Got It
Step 5: Create Your Starter Device Profile
Choose Option 2
Add a Device Profile
Create a new one
On this screen
Give your profile a name and description
Select “Switch” for the Device Type
Enter a random string for the Vendor ID
Click Add Capability
Find the Switch Capability, click add and close the window.
Click Next
Set the State to “Switch”
Set the Action to “Switch”
Click Create Device Profile
On the following screen copy your “Device Profile ID”
Step 6: Edit your connector.js file on the connector app tab
Step 7: Confirm that you can install this device in your mobile app
Put the SmartThings mobile app in developer mode and tap the “+” button at the top to add a device. Scroll down to My Testing Devices tap on it, and select your connector. Complete the OAuth login process and return to the Devices page. You will be prompted to complete the integration and your device will be added to the room.
@jody.albritton been waiting for this all summer, so pretty excited! I see you mention “part 2” in the opening of this post, but I can’t find it anywhere. Is it still forthcoming?
Coming this week. Were you able to create a device successfully using the above tutorial and can you provide any feedback, positive or negative? Thanks!
Jody I didn’t follow the specific instructions above because I already have a C2C connector setup on AWS using previous documentation/tutorials. And I’ve previously used the Developer Workspace to create custom Device Profiles. My issue is that my devices can’t quite be modeled right with the built-in capabilities. I was wondering if I could follow the other tutorial and use the new CLI to create custom capabilities and then maybe they would appear in Developer Workspace for use? I ran out of time to explore that this weekend.
Can’t wait for part 2!
Is it coming out soon?
Thanks for your help Jody.
Mobile app release triggered a regression. Fix is currently in QA/Internal testing and should be released to the public in the next two weeks. We are working hard to get custom capabilities to everyone using the new app with custom devices.
Ah ok, it is not just a matter of not knowing how to add custom capabilities, they are not available yet.
I’ll stop searching then!
@jody.albritton
Is it possible now to create custom capabilities using Cloud Connector Schema Device profile?
I see a lot of posts about problems with custom capabilities, but they all seem to be related to DTH in IDE.
Thanks for your help,
Charles
Yes it is. It works much the same way as the DTH but with device profile instead. Since there was a regression I left that part of the tutorial off, I will add it back as soon as I can.
Thanks @jody.albritton,
I have a couple of questions regarding Smartthings Schema Device Profiles:
1. Can you point me in the right direction for creating custom capabilities ?
Does it involve to manually modify the huge UI Manifest? I had a look at the documentation and I do not see how they fit together.
2. UI Display in Dashboard
My UI Display in Device Profile is setup like this:
But in the app it shows like this:
Any idea why?
3. Unable to use PH Measurement capability
I added the PH Measurement capability:
but it never shows up in the app detail page.
I also noticed the PH Measurement is not listed in the Capabilities Reference, should I be able to add it or not?
Charles
Hello @cdelasablonniere,
When you create a custom capability and its presentation, you can see it in the list when creating your device profile, which will generate the device configuration based on each capability’s presentation.
The messages “connected” or “checking status” appears if the capability in dashboard view (in this case temperatureMeasurement) has a null value.
For this capability, I could replicate the issue and I will document it and investigate more about it.
Thanks for your reply @nayelyz,
Where do I create the custom capability and its presentation? Is it somewhere in the Developer Workspace? How do I get it to appear in the list?
When I look at the custom capabilities documentation, it is not mentionned.
The temperatureMeasurement does not have a null value, but “connected” still appears:
Thank you for investiguating
Charles
Hi @cdelasablonniere,
You can use the SmartThings CLI, see this post where you can find documentation about the installation and commands; or API requests using a tool such as Postman (refer to the SmartThings API document).
Maybe some information was cached, so try updating the friendlyName and externalDeviceID in the discovery response of the Schema connector:
addDevice(externalDeviceID, friendlyName, deviceHandlerType)
Hi @nayelyz,
Things are progressing I guess :slight_smile:
I changed the externalDeviceID and friendly Name, but I still have the same result even after deleting and re-adding the device in Smartthings app.
  • I installed the cli from here
  • Then I tried to create a custom capability, but I got an authentication error:
  • I found the CLI documentation and it talks about requesting an access token. I tried that but the CLI I have does not recognize that command:
  • I then saw in the CLI documentation that I can download the CLI from the Developer Workspace:
    But I do not have “Tools” menu in my Developer Workspace.
So my questions are:
  • Are there different versions of the CLI ?
  • Why the one I got does not recognize the “request-token” command?
  • Am I suppose to have a “Tools” menu in my Developer Workspace?
Thanks for your help, it is appreciated.
Charles
The error you get is due to the lack of authorization, which can be done by:
  1. Creating the YAML file mentioned in the configuration part of the readme. Example of the file content:
default:
          token: xxx-xxx-xxx
  1. Adding the --token parameter in the command. For example:
smartthings devices --token=xxx-xxx-xxx
You will be using the Personal Access Token created in https://account.smartthings.com/tokens.
Also, to guide you using the commands available, the CLI provides a description of the command if you include --help. Example
smartthings devices --help
I will share your feedback about the documentation to continue improving it, thank you.
Hello @nayelyz, thank you for your help^.
I am able to create a custom capability, and I can add it to my device profile in the Developer Workspace.
Nothing is displayed in the Smartthings app though.
Here is my custom capability:
"id": "summerweather37297.orpmeasurement",
"version": 1,
"status": "proposed",
"name": "ORPMeasurement",
"attributes": {
    "ORP": {
        "schema": {
            "type": "object",
            "properties": {
                "value": {
                    "type": "integer",
                    "minimum": 0,
                    "maximum": 1000
				"unit":{
					"type": "string",
					"enum": [
						"mV"
            "additionalProperties": false,
            "required": [
                "value"
        "enumCommands": []
"commands": {}
and presentation:
"dashboard": {
    "states": [
            "label": "{{orpmeasurement.value}} {{orpmeasurement.unit}}"
    "actions": [],
    "basicPlus": []
"detailView": [
        "label": "ORP",
        "displayType": "numberField",
		"numberField": {
			"value": "orpmeasurement.value",
			"unit": "orpmeasurement.unit",
			"command": []
"id": "summerweather37297.orpMeasurement",
"version": 1
The CLI rejects the presentation because the “command” section is malformed, but I have no commands to write.
What am I doing wrong?
Charles
I suppose if you don’t need to have input from user, which mean just want to show a string, you should use state, not numberField.
Otherwise you can add setter into capability and write that into command than you can receive input from user.
I’m not sure it’s a just my little guess (*/ω\*).
Thanks for the tip @zldxkdlrj_dlcmaldml,
My capability hasn’t changed, it look like this:
"version": 1,
"attributes": {
    "ORP": {
        "schema": {
            "type": "object",
            "properties": {
                "value": {
                    "type": "integer",
                    "minimum": 0,
                    "maximum": 1000
				"unit":{
					"type": "string",
					"enum": [
						"mV"
            "required": [
                "value"
        "enumCommands": []
"commands": {}
and my presentation now looks like this:
"dashboard": {
    "states": [
    "actions": [],
    "basicPlus": []
"detailView": [
        "label": "ORP",
        "displayType": "state",
		"state": {
		    "label": "{{orpmeasurement.value}} {{orpmeasurement.unit}}",
"version": 1
The documentation doesn’t help much and the error message I get from the CLI when I try to create my presentation is useless:
I am trying to simply display a value here, nothing fancy, no actions…
@nayelyz : can you help me with that? What is missing in my presentation for it to work?
Thanks in advance,
Charles
Your attribute is ORP, so use ORP.value and ORP.unit in your capability presentation.
yes as @phiilh30 said,
formatting name should be {{<ATTRIBUTE_NAME>.[vlaue | unit]}}
so not {{orpmeasurement.value}} , but {{ORP.value}} .
