[ST Edge] Zigbee Driver for MOES 4-Button Scene Switch (TS004F) Plus Some Smart Knob Models
I just found a driver by obmaz that is working perfectly with the loratap 6 button. Under zigbee-tuya-button. So far, so good… all 6 work
Great finding !! thanks for sharing. He didn’t updated me about that…
I just commented on my github. :slight_smile:
You rock! Ive had this 6 button switch in a cabinet for well over a year lol. It works great so far. Thank you so much!
Hi @erickv, Hope you are fine.
I purchased two zigbee buttons and found out that they ae already in your fingerprint but am getting this ‘Device hasn’t updated all of the status info yet…’ so please can you advice?
Yet another button from Aliexpress
  • id: “_TZ3000_qgwcxxws/TS0041”
    deviceLabel: “Scene Switch”
    manufacturer: “_TZ3000_qgwcxxws”
    model: “TS0041”
    deviceProfileName: button-battery
@erickv , Can I get a reply please?
This is message appear when the reception of the ZigBee signal is bad or when only part of the ZigBee parameters received. You can ignore… no change require in the driver.
Hello, could you please help me adding it.to your driver? [IMG_8242] Its a scene switcher I found on aliexpres Tuya ZigBee Button Scene Switch Intelligent Linkage Smart Switch Battery Powered Automation This is the link https://a.aliexpress.com/_EQUDTbv
    deviceLabel: Zigbee Tuya 1 Button
    manufacturer: _TZ3000_fa9mlvja
    model: TS0041
    deviceProfileName: zigbee-tuya-button-1
Should work with @zambobmaz driver , try to install from his channel here:
https://api.smartthings.com/invitation-web/accept?id=2d6da83b-ae22-4fda-8af5-bbb8890872d4
Hello.
Can you add finger print to the tuya button edge driver you made?
This is a 4-button remote control purchased from Ali.
Manufacturer Code: _TZ3000_j61x9rxn
Model: TS0044
Can you please add screenshot after pairing with Zigbee Thing MC . history tab of
Model: TS0044
I added image
Model: TS0044
Added by @zambobmaz ,
Can you please check
thank you!!!
hello.
Can you add a fingerprint to the tuya 3_button remote edge driver?
Manufacturer Code: _TZ3000_ngsph3oj
Model: TS0043
Open an issue to @zambobmaz in his github and ask to add this device to his driver.
Hi everyone, do you know if there are scene change buttons that indicate whether the scene remains active or inactive? the LEDs that I purchased only light up when pressed, when the button is released the signaling LED goes off, and I don’t know if the scene is active or not…
uuua
I don’t know scene switch that can monitor your scene and remain active while scene is active.
The switch itself probably cannot, but there are some switch models where you can get the same end result programmatically.
I posted a detailed answer on this topic in the following thread:
Scene Controller with LEDs indicating if Scene is Active?
Hi @erickv !
Thanks for working on this driver.
I’m having a bit of an issue, though.
I’ve purchased the following scene button:
https://a.aliexpress.com/_oD7HUgJ
Yet it identified as the 4 gang one (T Z3000_ja5osu5g | TS004F).
I’ve tried every version of the drivers in your channel with no success. Non of them are showing up when trying to select a deiver other than Wesley’s or Zigbee Thing.
Is there anything I’m missing here you can help me with?
Thanks in advance.
