[ST Edge] Zigbee Driver for MOES 4-Button Scene Switch (TS004F) Plus Some Smart Knob Models
Try @zambobmaz driver. Should work fine. This is the link to his channel:
https://api.smartthings.com/invitation-web/accept?id=2d6da83b-ae22-4fda-8af5-bbb8890872d4
Hi, May i know which Edge Driver you are using now?
I do not manage to config it as dimmer using rotating
I’m using the “Zigbee Button Remote Driver [YG] 1.3.8” since it works with my device’s fingerprint (_TZ3000_qja6nq5z) but never understood how to toggle modes and configure it as a dimmer for direct pairing with a Zigbee light bulb. If your device fingerprint is compatible, you can find the driver at Yakov’s SmartThings Channel and Drivers
Hi @erickv,
Any possibility of adding the new Aqara Rotary Knob Dimmer H1 to your knob driver?
This is a NEW nice looking device (https://a.aliexpress.com/_EviSrgz).
I can’t find any driver that works. I have an Aqara M2 hub bridged to the ST hub, but ST only “sees” the button presses not the rotary events.
And I’d like to control some dimmable bulbs (non-Aqara) with this knob.
The info I got from @w35l3y driver is:
Thank you.
@iquix , should have an edge driver for, lumi.remote.rkba01.
You can try to install from his channel here:
https://bestow-regional.api.smartthings.com/invite/qWjB0pNyY62y
Zigbee Button
PERFECT, works like a charm.
Single, double and long presses.
Rotary appears as dimmer.
Rotary while pressing appear as color temperature.
Thank you very much.
Next question: is there a way to link this button dimmer level directly to the dimmer level of a bulb?
I guess I can use the “Scene Switcher” from @mocelet but perfect would be to direct link the dimming levels of the button and bulb.
Once again, thank you.
Maybe with a Smart Lighting routine. If that’s not possible, you can use the Rules API to “copy” the dimmer level of the button to the light (you can see this example here which copies the level of a virtual dimmer to a light).
I’m doing that with a simple rule in Sharptools.io , @joshua_lyon . For me this is much easier than Rules API.
The advantage of Rules API is that it’s local so it’s faster and more reliable than depending on two clouds. And now it’s done directly in the advanced website, before that it was a bit cumbersome.
Rules API worked great. Problem solved.
@dotan_shai and @mocelet, thanks a lot for your support.
Did something happen recently with either the driver or the hub firmware? I notice my 4 button moes switch is constantly flashing all 4 buttons randomly.
I think it’s a sign of a almost empty battery.
I’m using Nedis 4 switches ( not Moes ).
Hi,
I have this button / dimmer from tuya, which can be rotated and pushed: https://www.aliexpress.com/item/1005007720682666.html
Manufacturer code _TZ3000_402vrq2i
Model TS004F
Have tried a few drivers from this thread but haven’t found anyone that shows up in the driver list for the device.
Thanks in advance!
I’m trying to set up this device:
It seems the fingerprint is TS0044. Additional info:
Device EUI 4C5BB3FFFE8389C9
Cluster 0000
Manufacturer _TZ3000_kfu8zapd
Model TS0044
I’ve installed this driver on my Smart Things v2 hub:
  • Namebutton-battery-v1.4.4
The device is paired to my phone app and Smarthings installed the generic Smart Things zigbee switch driver. When I go to the ‘driver’ section and try to change it, the driver button-battery-v1.4.4 doesn’t show up. The only drivers that I can choose from are the Samsung zigbee switch, and zigbee thing.
Any idea what I’m doing wrong?
A developer need to add the fingerprint that you found to an edge driver.
I suggest ask @zambobmaz via an issue in his github here:
His channel can be found here:
Thanks! Will post issue there! :slight_smile:
I ended up buying this “el-cheapo” from AliExpress.
I can’t see any model number in description, but according to ratings section photos it should be ESW-0ZAA-EU. I can see some ratings with people comenting that it works well with HA. Also I can see some comments in this topic regarding this model, but still unsure if it will work or not.
Could someone confirm?
https://www.aliexpress.com/item/1005007895254036.html
Is supported by @zambobmaz Tuya Button driver. Here is his channel:
Hi @erickv , any way to add support for this device in your driver?
This button supported by @zambobmaz driver . this is his channel:
