[ST EDGE] Z-Wave Siren Driver Channel - including specific Zooz models
This driver provides support for some Zwave sirens. Currently only the Zooz ZSE19, using some of the methods Kevin implemented as a DTH but now as an Edge driver.
The Z-Wave Siren CS driver includes specific support for the following devices:
name model fingerprint notes
Zooz Siren ZSE19 027A-000C-0003 Supports triggering of WAV sounds 0-99 via “dimmer” interface.
Driver may be expanded to support other sirens in the future as needed. Please let me know any suggestions or feedback.
To use this driver:
  1. Use the invite to enroll your hub to the channel.
  2. Click “Available Drivers”
  3. Click the “Install” button on Z-Wave Siren CS
  4. For an existing device, you can use the app to change to the new driver. Go to the device tile, 3 dot menu, Driver, Change Driver.
  5. If this doesn’t work or its a new device, exclude/include as per the instructions for your particular device.
  6. If this driver works for you and you’d like to buy me a coffee thanks!
– Special thanks to @Dennis for loaning me a ZSE19 to develop/test with.
Very nice! I know a couple of people have been waiting for this. :sunglasses:
Wow that timing. Just started looking into how to add an edge driver for a new ecolink siren.
Added temperature and humidity offset Settings for the ZSE19.
 Driver Id    3c1fc4d3-82f5-4b74-b075-3ee8215caa8d
 Name         Z-Wave Siren CS
 Package Key  zwave-siren-cs
 Version      2024-07-13T16:38:05.0425829
Thanks man, much appreciated! :+1:
Corey, you’re my hero. Marry me? :stuck_out_tongue_winking_eye:
I have to go dig out my old notes from when I used the sounds in a bunch of my automations. I had found a free (then) text-to-speech sound generator and created a bunch of specific announcements for family members. I really missed those and I’m so glad to get them back.
Thanks for updating the ZSE19 to Edge. I just found it today. I missed having the custom sounds. I do have one issue thought. When I set a routine, I get a 1 second burst from the siren before the sound plays. Is there a way to prevent that? My current settings are:
Turn On
Volume: 100%
Dimmer: 35%
All the other setting are turned off.
Try unchecking Turn On. Setting the Dimmer value should be enough to turn it on.
Thanks, I didn’t realize that you could unselect the power option by clicking on it. I thought you needed one selected.
Hi @csstup Are you planning drivers for the Aeotec Siren?
I can if someone loans me one to develop with.
