Hi! just bought the NEO Coolcam Siren, added it to smartthings but i dont see how to set / change any settings. It seems to be using an edge driver, tried adding a custom DTH but that does not seem to do change anyting since is running edge driver.
Any tips? Unroll from edge drivers and add it again?
Yes I’m in the same boat .The driver doesn’t work.
You need to delete the device , go into you hub choose the 3 dot and then zwave utility or something mine is in French.
After that in your hub the 3 dot again , choose pilote and remove the wave smoke pilot .
Install the DTH from @krlaframboise .
You should be ok I think you have 10 sound .
