[ST Edge] Sony Bravia TVs
for the last two days my Sony has stopped working. I tried deleting the object and driver from the hub. I reinstalled the driver, but when I search for the new device nothing appears. Can someone help me?
Mine wasn’t working the other night either. Seems to be OK again now. I have always found it a bit finicky.
i’m in the same situation… did you guys find somethings?
My Sony TV is operating normally in ST with this driver.
I haven’t had any problems.
Mine ceased functioning last week, still has not bounced back. App says the TV is offline
EDIT: it is finally back in operation.
@philh30
I had this working with my Sony TV.
Power button stopped working.
Removed TV from ST.
Re-installed driver.
Scan does not find TV.
Help?!
It’s been VERY wonky since the last two hub updates.
Hello Guys
Thanks philh30 by the driver.
I always used this driver no problems , but I had to exclued my TV from smartthings and now it can’t find my TV on scan. Some one figured it out how to fix?
Having the same issue with two of my TV’s. Removed devices from Smartthings to troubleshoot a different issue and when I try to rescan, nothing is found.
Tagging @philh30
I know you said this driver is low priority, could you please have a look at the problem a lot of us are having?
Much appreciated.
Any news???
I’ve been enjoying being able to control my Sony TV with Smartthings but it stopped working recently.
TV became off line so I removed it and tried to reinstall but now when I scan it isn’t found.
Tried uninstalling the driver and reinstalling but that didn’t work.
Unfortunately the developed isn’t supporting this any more? Shame because it was really helpful.
The intercommunication is sometimes shaky. Had to try 3x this morning but back to normal after this.
Can you please explain what did you make in order to make this work ? As others said , I’m unable to detect my TV in ST app.
Good question! :wink:
I rebooted the Sony, redid the procedure as OP explained, for setup in the TV. Then, retried on android (SmartThings), 3 times.
I had network errors, announced after 20s. But retried anyhow. Somewhat got lucky on third time. The reason I tried so many times is because, I had such a behavior before (net err).
Hope it helps, it is not very scientific, but worked for me. Somehow every 2 months I have to repeat as it looses again the link. Yet my IP addresses are always the same on my network (DHCP table). Go figure.
Had the problem again because of a power failure. Went into advanced web app and refreshed the device in commands. Instant connection.
Ill give that a try as well, after every power outage.
Hi everybody, i just debugged the driver and saw why it didn’t detect my Sony (at least in my case). I’ve created a temporary channel with the bugfix. If you want you can add it to your SmartThings and try it: Invitation. Please reply if it works, so that I can send it to the original dev and maybe, he can modify it in the original code.
The original developer is no longer contributing in the ST community. You might be able to get @csstup to add it to his forked version of the original repo and publish it in his channel.
