[ST Edge] Sony Bravia TVs
This driver works great !!!
It found my Sony TV and I was able to control everything as in the original driver.
It even works without entering the passkey !! You made my day and I want to buy you some coffee and pizza, write me a PM…
Phil no longer develops for the ST platform and is not active in this forum.
I’m referring to the driver that @Noemis did. This one works great.
Phil driver is not working and not detecting my Sony TV.
Ah, wasn’t clear since you didn’t quote the post you were replying to.
This works for me as well, on both my 2018 and 2022 Bravia’s. Appreciate the time you put in to get this working!
Hi @Noemis
I have earlier reported error messages
Did you fix this bug?
If the repairs to the driver were minor, can you share information about the repairs? I have a goal to make my own version of the driver.
Thank you, I have my TV back in SmartThings and it’s working well.
Sometimes ST app shows TV is off when TV is on, any settings I can change to fix this?
Edit; I turned TV off with Google Home and then on again with ST and it works normally?!
OK so here I am in 2025 getting started with ST. 1) am I the only one that’s generally technically inclined in most things that doesn’t understand what I should be doing to get this to work? :joy: Does anyone have a video link for how this stuff is added? 3) help! :joy:
Did you tried the with the driver that @Noemis did ? If no install it from here:
Configure your TV setting as explained in the 1st post, and try to pair your tv.
I think I missed the part where I first need a hub. I’m currently trying to find one to buy online. Then I believe I just need to add the hub to ST and then click on the drivers and add them to the hub?
Having an Aeotec SmartThings hub is critical. After you’ll acquire to SmartThings hub, install the driver from the link I mentioned and try to pair your Sony TV.
Does it work for all bravias? I have the Bravia 7 QLED
If you can follow the steps for installing it should work.
I have two Sony TV’s , both are wired connected to my router and both have a static IP’s addresses.
After pairing everything is working well. But, after few weeks both TV become none responsive. They still appear online but the TV control is not doing anything. The error I’m getting is “A network or server error occurred. Try again later” when trying to turn on/off on both.
Of course that removing the TV’s and re-adding sort the problem, but this require to repair all routines and fix Sharptools dashboard until this happens again.
I must say that if only One Sony TV is connected (the other is connected via Wi-Fi and therefore can be detected by this driver since this is different LAN Gateway) , there are no problems and everything works for years.
I can send CLI logs, and perform any test that can help.
@philh30, @Noemis can you please help ?
Are both TVs working normally in Google Home App?
I didn’t tried Google Home. Both TV are working fine with a simple TV remote app in Android phone while nothing works with Smartthings, I need manually to enter the IP address in this app.
They are also working fine with this driver, But for few weeks….Yesterday I removed and added again. For now all is working. I will update if my issues will return….
Driver worked for me too, thanks for fixing the buy.
My solution for me , connecting both TV to wired network. Since then no issues anymore
My both TV’s are ONLINE but can not be controlled anymore.
I can remove add again, but I want to know the root cause for that issue. @Noemis can CLI log can help you ? Everything worked fine for few months. I suspect that streaming a video from YouTube cause that but I’m not sure….
