There’s an driver for the Ecolink Chime+Siren (ISZW7-ECO) on Ecolink’s Edge Driver Channel.
Installation Instructions:
- Click the link above
- Log in with your Samsung Account
- Click the “Enroll” button next to your hub
- Click the “Available Drivers” button
- Click the “Install” button below Dome Siren
- Add the device
(Step 3 can take a while, but if it gets stuck try opening the original URL in a new browser tab)
Features
The features below can be used from the device’s Details screen, Routines, and Rules.
Power Source
The device has a battery backup and the Power Source attribute changes from “AC Power Supply” to “Battery” when it’s unplugged so if your hub is connected to a UPS you can use this device to detect a power outage.
Switch
The switch state changes to “on” when the Siren, Chime, or Custom Sound is activated and the “off” command will stop whatever sound is being played.
Siren
- Commands: siren/off
- Sound (select from 7 options)
- Volume (1-100)
Chime
- Commands: chime/off
- Sound (select from 26 options)
- Volume (1-100)
Custom Sound
The device comes with 30 built-in sounds numbered 1-30 and if you use a microSD card you play your own custom mp3 files numbered 31-125.
- Play Sound (plays the specified sound #)
- Volume (1-100)
The “Volume” and “Sound” options get stored so unless you’re using different sounds and volumes there’s no need to set it in every Routine.
Device Details
Routines (IF)
Routines (THEN)
