[ST Edge] Personal Tuya Devices - Generic EF00 Device
These numbers mean the datapoints used for each manufacturer in the order of the profile definition (in this case: temperature, humidity and battery)
So, DP=1 for temperature, DP=2 for humidity and DP=3 for battery. These are the default datapoints. You may override them in the settings.
The presence of asterisk means some kind of customization, usually related to the rate.
Hey wesley, any chance we can get this solar alarm supported? _TZE284_nlrfgpny
I tried the datapoints from this github
But no dice. I got it to set off the siren once or twice but then it wont turn off and i have to pull the battery :frowning:
Your DP seems to be correct. Please send your setting. Maybe there were problem with the received signal while testing ?
Have you managed to get this device working?
No, im not able to get it to work.
i ended up getting it to work. i had the incorrect dp for the alarm
Could I get a hand getting some soil sensors working? I followed all the steps in the following post since I have the same device but I keep getting the same error message. I have tried unpairing/pairing a dozen times, have moved the device right next to my hub, and have waited 24+ hours
Can you please share the correct DP that works for you for others that will come across this device ?
Your RSSI value (-93 dBm) seems to be very poor it should higher than -70dBm (like -60dBm or -50dBm). Can you please do your test when your device is near by your hub ? If everything works well consider adding some repeaters in the way between final location and your hub.
Hi, thanks for the reply. That was the moisture sensor I have outside. I do have some repeaters on their way to fix that issue.
The other sensor I have laying right next to the hub and I’m experiencing the same issues with it
Please share your device Finger Print. Do you know which DP’s your device is using ?
Is presentation ID the same as fingerprint? Sorry I’m not familiar with what DP is either
Edit: oh must be device profile. It’s currently on generic-ef00-v1
yea, so the DP for alarm is 13, DP for audio i set to 21 (this might be wrong since i dont think the volume can be changed on this siren, but this allowed me to change melodys somewhat, its wierd) and dp for battery is 15.
I wish there was a way to use siren or light strobe only, but this is better then nothing i guess.
For _TZE284_aao3yzhs
Go to setting and change the profile to temperature and humidity . go setting again and change to +Battery. Use the following DP for temperature, humidity and Battery:
            [3, "soil_moisture", tuya.valueConverter.raw],
            [5, "temperature", tuya.valueConverter.divideBy10],
            [9, "temperature_unit", tuya.valueConverter.temperatureUnit],
            [14, "battery_state", tuya.valueConverter.batteryState],
            [15, "battery", tuya.valueConverterBasic.scale(6, 60, 0, 100)]
3, 5 , 15
Try DP 102 looks like you can control the mode:
102,  "alarm_mode", tuya.valueConverterBasic.lookup({alarm_sound: tuya.enum(0), alarm_light: tuya.enum(1), alarm_sound_light: tuya.enum(2)}), ],
Just checking- but will this fix the error I’m seeing in the one screenshot that says “This device hasn’t updated all of its status information yet. Check again later.”
And how do I edit DP (this does mean device profile right?)? Is that done on the advanced SmartThings website?
I’m answering in PM
Theirs no spot to input that unfortunately
If this setting is important for you , you can connect your device to Tuya hub and configure as you need. Then, connect back to ST. The setting will be stored in the device.
