Interesting.
It is acting as an actual switch, not a push button.
Hopefully, using the 0xEF00 cluster, the commands will be different.
Otherwise, I probably will need to ignore the state and use something like a toggle command to implement momentary capability for this cluster.
@brogio with Wesley driver, remove the battery from the Fingerbot, wait 10 seconds and then reinsert the battery again.
Wait 10 seconds and refresh the device view, you should be able to discover much more Data Points.
Knowing the datapoints isn’t enough.
I need to know the current values so I could understand why it is behaving this or that way.
I need to understand the domains… 101 is 0/1/2 ? I don’t know.
It may be working as a switch because its current mode is Switch.
We will never know without the current values.
Enum 1 is the smoke detection. 1 is clear and 0 is detected
Boolean 4 detects whether the smoke detector has been attached to its mounting plate. It reacts to a button that is pressed when the detector is twisted into the mounting plate that attaches to the ceiling. “True” when the button is released and the detector is off the plate and “false” when the button is pressed down and the detector is seated in its mounting plate
Enum 14 detects battery level. “2” means batteries are full (100%), “1” is low (50%), “0” is empty (0%).
This got added as a Generic device in Smartthings and though I chose ‘Smoke detector’ in the driver profile, nothing gets displayed probably because you have not mapped the data points yet?
@w35l3y, Thanks for your quick response. I am not sure what you mean by common problem. Am I right in understanding that you have added the data points to the driver based on the screenshot I provided?
I am using Android and not iOS.
Yes, it has a test button but there is no data point associated to it.
@Mitokafander, Just to let you know that Wesley has kindly added our smoke detector to his Beta driver and it is working perfectly fine. I was also able to add it to the SHM directly without the need for a Virtual switch so you may want to try this too.
Is it possible to add this pressence sensor:
_tze204_sbyx0lm6
From this link8
ZigBee 24G MmWave Radar Human Body Presence Motion Sensor For Light Switch Luminosity Detection 110/220V Tuya Smart Life Home https://a.aliexpress.com/_mLitGgS
Attached also screenshots of cluster and datapoints info.
This switch worked , according to Elad , only when selecting 3 switch profile . When selecting switch profile , NO response from module. Can you please comment…
