I have three tuya zigbee presense sensors in the house. One is functioning, the others are showing no presense detected even though i wave in front/directly below them.
The settings on two of them are exactly the same. The last one is new/factory set.
Already tried to held setup to add them again(without deleting them) and it unfortunately did not work.
I don’t know if this is the detailed view as you requested but hope it helps.
It could also be the hub thats trouble, i actually think thats more likely.
Let me know if you need more info.
I bought some 24V COB light strips on eBay that use a Tuya Zigbee controller, @Mariano_Colmenarejo added it to his Zigbee Light Multifunction Mc and they work perfectly. I don’t care for RGB, mine are CCT only, but he has added many others the use the same (appearance) controller.
Is this the correct Tuya ZY-M100 that works with this driver. Imconfused because it says wifi but this is the one that comes up when ive clicked on links others have posted.
This driver only works with zigbee devices that use 0xEF00 cluster.
For details, please read the first post of this thread.
If you have any doubt, let me know.
There are very similar models to the one you posted that use zigbee.
