[ST Edge] Driver for GE/Jasco/Honeywell Z-Wave Switches, Dimmers, Fans, Outlets, and Plug-Ins
@philh30 I have one not on the list as well…jasco dimmer switch 700 series:
0063-4944-3433
ThNks!!
@philh30 I’d like to add an ancient one to the list if I might.
GE Dimmer - JAS12724 - GE 12724 -
Manufacturer Code that I’m getting from the Devices page.
0063-4457-3230
thank you.
@philh30 Hi, it looks like there’s a new model Ultrapro In-wall switch, with the fingerprint 0063-4952-3333. I need to be able to do the double-tap control, but without your amazing driver, I cannot. Please add this. Thanks!
@philh30 I also have these switches 0063-4952-3239. I bought what I thought were 0063-4952-3135 because I just bought the same thing I bought previously from the same vendor, but apparently they are not the same.
Would you be able to add them? How can I help?
I have a plug-in switch that is going off-line. I noticed that it is using the generic Z-Wave switch driver and I can’t change to this driver for the GE (& similar) switches. It’s Manufacturer Code does not appear to be in the driver. Can it be added? It’s 0063-5250-3031. Thanks!
@philh30 still around?
Here’s yet another one, similar to the ones mentioned earlier:
0063-4952-3138
I think it’s a “Jasco ZW4009”.
Same request, mainly looking for the double tap feature.
Isn’t this open source?
You could certainly fork his repo, add the fingerprints, and do a PR. But, Phil still needs to merge it into his repo, package the driver, and update the channel. However, Phil mostly develops for Hubitat these days and isn’t very active here.
@csstup indicated that he is going to take up maintenance of this driver going forward, but there hasn’t been activity in his repo for GE/Jasco code. I’ve been doing some work on the Schlage lock driver and hope to be able to merge that code and add fingerprints for GE/Jasco devices as well.
I have all the GE/Jasco updates that Phil had done over the years consolidated into the Z-Wave Switch CS driver so its one large driver for all devices. 0063-4952-3138 isn’t supported yet however.
How do we go about getting your updated driver? Does it include 0063-4952-3333? Thanks.
Corey’s driver is based off of Phil’s. It doesn’t include your device’s fingerprint.
Hmm, do we know if anyone is able to update these drivers? If not, can anyone point me in the right direction to doing it myself? In the current, state I am facing real limitations with these newer switches.
Check out this driver. It might help.
Unfortunately, that one didn’t work either. However, I’ll post a reply to BigThunder in that thread, and see if he might be able to add the device ID I need. Thanks!
Added support in Zwave Switch CS for:
  • Enbrighten Paddle Dimmer 58438 0063-4944-3430
  • Enbrighten Paddle Switch 58433 0063-4952-3239
  • Jasco Switch (not sure of model) 0063-4952-3138
  • UltraPro Switch 59347 0063-4952-3333
If you already have Zwave Switch CS installed, the update will arrive automatically within 12 hours. Version 2024-05-01T15:45:46.058079426
Note this version also captures the firmware versions of Jasco (GE/Ultrapro) devices on the “Information” page, if joined after this update.
Also added support for this plugin.
I can confirm that your driver works for the new switches, and I can finally use the double tap again. Thanks so much!
Yay! Everyone should do this. Thank you, Corey, for adding this very useful feature. :nerd_face:
Hi - I have an UltraPro 59350 (instructions also list 59372 and 59373 and ZWA3016 - I suspect these are the two pack and four pack designations). The manufacturer code is 0063-4944-3433, is this a relevant switch to add to the “Z-Wave Switch CS” driver? When adding this to SmartThings it showed up a GE/Jasco??? Could this be added please?
Second question - what is double tap being used for by various folks? Is this something that I can use to trigger some other action?
Thanks.
3 posts were split to a new topic: What do you use double tap for?
Similar to above - Ultrapro in-wall smart dimmer - 59372. Looks like the edge driver isn’t updated with the new 700 series chip switches.
Please and thank you.
