[ST Edge] Does the order of declaring components has any meaning?
Hi,
I was assuming the list of components in device profile is ordered.
However, when I tried to change the order it seems it has no effect.
Specifically, for dual gang switch that has
2 child switches that control relays and the main component (which has switch and different measurement capabilities) that controls both switches,
I’m trying to put 2 child switches before the “main”, so all buttons would be together and then all voltage, power, temperature etc would be below.
However, the main component is still shown first.
I’d like switches1 and 2 to be on top
Yeah, I’ve already experienced this issue.
To solve this problem, you have to make a presentation with smartthings cli explicitly, and then put that vid into the profile yaml file.
I hope auto-generated presentation will keep the order of the components in the profile.
Hi @iquix ,
Thank you very much for your answer.
Making custom device config helped with detail view.
However, the order of components in automation view was not affected by device config.
