[ST Edge] Custom device config
Hi,
I created an edge driver for Aqara dual channel switch.
The driver creates device with switch capability under the main component and additional 2 switch components.
The detail view is shown below:
In order to make sure the Switch1 and Switch2 are shown above the main component, I needed to create a custom device config, as was suggested by @iquix in [ST Edge] Does the order of declaring components has any meaning?.
However, device config did not help with the order of components in automation view.
Further, in automation view it is not possible to know to which component the switch capability is related.
Hence, I have 2 questions:
  1. How it is possible to specify the order of capabilities in automation view?
  2. How it is possible to provide a custom label to capabilities in automation view
Yes, the engineering team is already working on this issue, it’s not related to Edge drivers only, it affects all multi-component devices.
About how to identify the components, they follow the order you defined in the Automation View. Remember you can check your presentation as follows:
// Using the ST CLI command:
smartthings presentation vid -j
//Sending a REST query to:
https://api.smartthings.com/v1/presentation?presentationId=vid&manufacturerName=SmartThingsCommunity
Thank you @nayelyz ,
While it seems the order of components in detailed view follows one in device config, it is not so for automation view.
Here is my device config:
device-config
mnmn: yashik
version: 0.0.1
type: profile
dashboard:
  states:
    - component: main
      capability: switch
      version: 1
      idx: 0
      group: main
      values: []
  actions:
    - component: main
      capability: switch
      version: 1
      idx: 0
      group: main
detailView:
  - component: switch1
    label: Switch1 Test
    title: Title
    capability: switch
    version: 1
    values: []
    patch: []
  - component: switch2
    capability: switch
    version: 1
    values: []
    patch: []
  - component: main
    capability: switch
    version: 1
    values: []
    patch: []
  - component: main
    capability: temperatureMeasurement
    version: 1
    values: []
    patch: []
  - component: main
    capability: powerMeter
    version: 1
    values: []
    patch: []
  - component: main
    capability: energyMeter
    version: 1
    values: []
    patch: []
  - component: main
    capability: voltageMeasurement
    version: 1
    values: []
    patch: []
  - component: main
    capability: amberpiano10217.currentMeter
    version: 1
    values: []
    patch: []
  - component: main
    capability: signalStrength
    version: 1
    values: []
    patch: []
  - component: main
    capability: refresh
    version: 1
    values: []
    patch: []
  - component: main
    capability: configuration
    version: 1
    values: []
    patch: []
  - component: main
    capability: healthCheck
    version: 1
    values: []
    patch: []
automation:
  conditions:
      label: Switch1
      capability: switch
      version: 1
      values: []
      patch: []
      exclusion: []
      capability: switch
      version: 1
      values: []
      patch: []
      exclusion: []
    - component: main
      capability: switch
      version: 1
      values: []
      patch: []
      exclusion: []
    - component: main
      version: 1
      values: []
      patch: []
      exclusion: []
    - component: main
      version: 1
      values: []
      patch: []
      exclusion: []
    - component: main
      version: 1
      values: []
      patch: []
      exclusion: []
    - component: main
      version: 1
      values: []
      patch: []
      exclusion: []
    - component: main
      version: 1
      values: []
      patch: []
      exclusion: []
    - component: main
      version: 1
      values: []
      patch: []
      exclusion: []
    - component: main
      version: 1
      values: []
      patch: []
      exclusion: []
  actions:
      capability: switch
      version: 1
      values: []
      patch: []
      exclusion: []
      capability: switch
      version: 1
      values: []
      patch: []
      exclusion: []
    - component: main
      capability: switch
      version: 1
      values: []
      patch: []
      exclusion: []
    - component: main
      version: 1
      values: []
      patch: []
      exclusion: []
    - component: main
      capability: refresh
      version: 1
      values: []
      patch: []
      exclusion: []
    - component: main
      version: 1
      values: []
      patch: []
      exclusion: []
    - component: main
      version: 1
      values: []
      patch: []
      exclusion: []
As you can see the order of components in automation view is
automation:
  conditions:
      capability: switch
     capability: switch
  - component: main
    capability: switch
However, it is not preserved, not for actions, not for conditions
Ok, it seems it affects those that use a number in the component name (eg. switch1, switch2). When I create a profile and presentation using names without numbers, the order is followed correctly.
I’ll create a report for the engineering team to look at it. Thank you for bringing this up! :smiley:
Also, did you set manually the value of mnmn: yashik? When we create a device presentation, the default value for mnmn is SmartThingsCommunity.
Hi @nayelyz ,
Thank you for your response.
Yes, mnmn was changed manually.
The idea was to use it as a filter (for example, to use different mnmn for capabilities/presentations used for tests and for released drivers).
Is it a problem to modify this field?
I made some tests to check and there are no issues when we create the presentation and use it on a device. However, I asked the engineering team to know if there are any restrictions. I’ll let you know their feedback.
Hi, @ygerlovin. The ability to set a custom mnmn value is considered a bug (thank you for letting us know!).
The reason is that if this is possible, devs could enter some keywords that would cause a conflict, eg. “SmartThings”. The engineering team is working on this fix and later on, this field will be set automatically.
Please, consider this for the presentations you already created.
I’ll let you know when the fix is released.
Thank you @nayelyz .
So I guess the best way is just to remove it from yml/json files
yes, you can create a device-config without adding this field and it should assign “SmartThingsCommunity” automatically and you can use that presentation normally.
