I don’t use the Aqara app/hub so I cannot answer that one.
Got it, no worries. From some of the other videos I have seen from folks using the Aqara app, this is possible. Was just curious. Thanks
I hope I found the right thread now…
I have been using @ygerlovin edge drivers for Aquara contact sensors for a while without problems. So I ordered a bunch more and installed them around the house. However, they seem to malfunction with sliding doors. For some of them I get 3 readings for each open or close event. Since Smartthings truncates the timestamp for integrations, my Sharptools.io dashboard is getting messed up since it does not know which one is the latest reading and whether it is an open or close.
Has anyone seen this behavior before and do you have any recommendation?
I’m trying to get rtcgq01lm to work. It states that it’s supported by it shows up as Zigbee Thing after paired. Which driver from this channel is supposed to support rtcgq01lm? I installed Zigbee Sensors Edge Driver [YG] 1.8.16
Hi! Is there an edge driver available for this sensor? From what I read it looks like the fingerprint was to be added, but I’m unsure if it was really added or if someone has used it. Thanks!
For Aqara Motion Sensor P1, does the current “Zigbee Motion Sensor” Edge driver work? I saw Aqara motion sensor in the list of supported sensors in SmartThings app, but only for T1 and High precision versions, not P1. Zigbee Sensors Edge Driver [YG] 1.8.16 works for P1, but if I don’t have this driver installed, it will automatically use Zigbee Thing driver, which only shows connectivity. I also cannot select a different driver for P1 once Zigbee Thing is the selected driver, even though Zigbee Motion Sensor edge driver is also installed on my hub.
No, ZigBee motion sensor stock driver doesn’t work with P1, you need to install YG Driver.
Hello, I would like to request a driver for the following Aqara Water Leak Sensor:
SJCGQ11LM
Zigbee capability:
Zigbee capability
Amazon has it for sale. Not able to post link since I am new user.
Fingerprint
This is what I get from the events:
basicHtml: “
| Model | lumi.sensor_wleak.aq1 |
| Manufacturer | LUMI |
| NetworkId | 0xB462 |
| Zigbee EUI | 00158D00027B086B |
| ZCL Version | 1 |
| APP Version | 4 |
| Server Clusters | 01={ 0000,0003,0001 } |
| Client Clusters | 01={ 0019 } |
| Test bar | <progress value="30" max="100" /> |
Thank you!
Use this one
Can this Third Reality vibration sensor be added to the Zigbee Thing [YG] v1.0.2
: 3724840a-2b1d-4f6b-9683-e8e0155445ee driver? Here is the device summary and attributes:
UPDATE: NEW Third Reality Vibration Sensor - Custom Edge Driver Available
I received a notice from Ivan at Third Reality stating the they have developed a Custom Edge Driver for the following Vibration Sensor:
Open this link in your PC browser: Third Reality Driver Channel Invitation
Log in your SmartThings Account.
Click “Enroll” --“Available Drivers” – “Install” to add this driver.
- “Scan for Nearby Devices” in SmartThings App to pair the Vibration Sensor with SmartThings hub.
This device is not listed as yet on Amazon. Once it is available I will provide a product link. I also plan to do a video on it features. I has a loud beeping sound that is triggered by vibration. The beepin (three sets of three successive beeps), can be disabled via a circuit board switch. It also has two toggle (0/1) switches that can be used to set the vibration sensitivity levels:
SENSITIVITY SWITCH SETTING:
1/1 = Low
1/0 = Med
0/1 = High
0/0 = Very High
Here is the sensor as displayed in the SmartThings app (iOS):
Bud
Bud’s Smart Home
@ygerlovin Your Edge drivers have been a life saver, thank you.
The only thing not working with your driver is the Aqara Water Leak Sensor SJCGQ11LM, is there any way to get this working again?
The only driver ST allows me to use is “Zigbee Thing [YG] v1.0.2” but this does not report the switching, if I try to set a routine it inly offers signal strength as a trigger.
ygerlovin is not active on the forum anymore.
Use Zigbee Aqara Water Leak Sensor Mc . It works for the SJCGQ11LM
Thank you so much I found it and it works well, I also got my temerature sensors working properly with the temperature drive so a big thanks.
I don’t suppose you know where I can get an edge driver for the Aqara cube MFKZQ01LM that is the last thing without an Edge driver.
I tried the Veon one but I don’t get and stat changes when I move the cube. I could be my cube is faulty.
I don’t have a cube. Did you look at this:
Thank you yes that’s the Veon one it populates as if its working but none of the actions (switches) work, honestly, I wouldn’t be surprised if it was my cube, it was nothing but trouble since I bought it.
@Anthony_S
Good afternoon, there is a driver for @Mariano_Colmenarejo aqara water leak mc that works normally.
Have you tried changing the battery?
Also, if you have no experience with the cube on the Aqara platform, it has to be rotated quite forcefully to register an action. Often, when I try to minimize the noise, it doesn’t work for me either.
It might be worth trying a new battery, when I first got it ir was fine, then I had to change the device handler (cant remember why) and it never worked right again,
It might be as simple as a low battery.
Hi everyone. I recently bought an Aeotech hub. New to Edge drivers and everything. I am trying to pair my Aqara sensors and Xiaomi Sensors to the hub with the driver installed and enrolled. I happen to pair 1 Xiaomi Sensor but the other 2 don’t seem to pair for some reason. It keeps showing vDev Controller but no device is being made. Also I cannot pair any of my Aqara and Xiaomi Contact sensors at all.
Here are the sensors I am trying to pair
Xiaomi/Mijia | MCCGQ01LM | Contact Sensor | LUMI/lumi.sensor_magnet
Xiaomi/Mijia | RTCGQ01LM | Motion sensor | LUMI/lumi.sensor_motion
Aqara | MCCGQ11LM | Contact Sensor | LUMI/lumi.sensor_magnet.aq2
Aqara | RTCGQ11LM | Motion and Illuminance sensor | LUMI/lumi.sensor_motion.aq2
