Continuing the discussion from Harmony Hub UK Intergration:
After following this thread and others all day, I have been able to set up the integration. I am however stuck at the stage where the Harmony hub is discovered and I am able to pick the Harmony activities in the ST app. When I click on done, an error message is returned; “You appear to be having issues with your network. Please check your network connection and try again”. my network is find and both Harmony and ST apps are working normally. Any suggestions to bypass the error message and save the smartapp settings?
