I popped a fuse today in my shop and the ST motion sensor v1 that was on the same power cct now seems to be NFG. I reset the breaker and ST shows permanent motion active on that device even when it’s not plugged in and the batteries are removed. I have rebooted the hub but it always shows “Active” for the motion sensor, anyway to reset this without deleting the device?
Here you go:
https://support.smartthings.com/hc/en-us/articles/200903280-SmartSense-Motion-Sensor-original-model-
When it rejoins, it will show up as the same device as before. No need to remove the device!
Thanks. I ended up removing the device from the network and re-adding it. It started talking again so at least it didn’t fry
@daven Don’t feel bad, I had two window sensors (z-wave) that stopped updating correctly at some point, had to remove and re-add them again for them to reset and start working. But that’s the ONLY 2 devices of my 80+ that i’ve had to do in over a year… so I consider it a rare occurrence.
