Firstly, I have to say this should not be tucked away at the bottom of a thread but should have its own!! (Tried all the other methods before spotting this) Love the fact there is no parent/child handlers and no app to update status! I have successfully added a couple of sonoff touch units, and they work great so far. I have a few two channel switches and can see in the preference for the device I have to change a setting to “True” for a two relay device but can’t work out how I actually create the second channel? probably being stupid but could you advise please?
I’m glad you like my handler, I’m not an expert at groovy but wanted something simple, which is what this is. For the 2R device, I realised that without creating a chikd you need 2 devices with the same ip address so the network I’d can not be used for the 2nd switch. I have made a different handler for the 2nd switch but as I wasn’t totally happy with it as a solution I didn’t put it on github.
Hi Mark,
Glad it wasn’t me being stupid! I would really appreciate it if I could get hold of the handler. Have about 10 sonoff touch unit’s, couple of basics and even a wemos D1 Mini that I have added using your handler today and they work great.
Hi Mark,
Works great!! thanks for adding the second handler.Really good job mate, exactly the way I was hoping I could get my sonoffs working with Smartthings
Hello @joelw135, this is great job. Many thanks to you.
Only one question I have .
Could you update source code little bit to make an switch on smarthing as primary source. I mean that after physical device was reboted or power outstage get stage of smarthing switch status. Current implementation grab status of physical device and update switch status in smartthing. Is it possible to make vise versa?
As after power outstage I have to update all switches in correct state in manual or via smart app.
That will be good to have an update from smarthing to physical device (instead current implementation physical device to smartthing) as it primary source of data and control.
I have an question. Does this approach require update flash memory as was mentioned on beginning of this thread? Or that is apply to fresh devices “as is” from factory?
As I can’t confrol Sonoff basic unfortunately. Device Network Id set as IP of device and only what I have now is "authentication is ok " and "refresh is active " and nothing more.
I had made the same with my panel Actiontiles or Sharptools. THe problem is that if I turn on a Sonoff device manually then the status update is not reflected in smartthings. Did you figured that out?
I have installed the device handler. It works great. Just what I was looking for.
I’m a newbie in the smartthings world.
But I have noticed in the code. That the update time for state changes is set to 1 minute. …Is it possible to make that time shorter? Or is that not possible? Does it make the traffic on the hub too heavy? or something?
