Tasmota Edge
Tasmota Edge is an Edge driver for SmartThings, that allows you to add your Tasmota supported devices as SmartThings devices.
It works with more than 2000 ESP (ESP8266, ESP8285, ESP32, etc) WiFi devices - switches, lights (CCT, RGB, RGBW), dimmers, relays, plugs, power strips, sockets, wall outlets, fan controllers, IR bridges, RF bridges and more.
Brands include Aisirer, Athom, BlitzWolf, BrilliantSmart, eWeLink, Girier, Globe, Gosund, Lohas, MagicHome, Moes, Shelly, Smart Life, Sonoff, Tuya, Zemismart and many other brands.
Find all Tasmota supported devices here - https://templates.blakadder.com/.
Read more about Tasmota Firmware here - https://tasmota.github.io/docs/.
Instructions for flashing Tasmota firmware - https://tasmota.github.io/docs/Getting-Started/.
This is a BETA release. It’s probably buggy and not all of the devices & features are supported or working.
Features:
- 100% local execution
- Real-time device status
- Pure Tasmota & SmartThings integration
- Virtual Device (for RF / IR devices that can be controlled by a RF / IR bridge)
Requirement:
- Samsung SmartThings Hub v2/v3 or Aeotec Smart Home Hub
- Official Tasmota Firmware >= v11.0.0
- Static IP address on Tasmota device and Hub
- Private Network - must be in one of these IP address range
- 10.0.0.0 – 10.255.255.255
- 172.16.0.0 – 172.31.255.255
- 192.168.0.0 – 192.168.255.255
Tasmota Supported Devices:
- Switch / Plug / Power Strip / TH (Temperature-Humidity) / Socket (1,2,3,4,5,6,7,8CH) - No Power Monitoring
- Metering Switch / Plug / Power Strip (1,2,3,4,5,6,7,8CH) - Power Monitoring
- Dimmer (1,2CH)
- Fan / Sonoff iFan
- Light / Bulb / LED controller (CCT)
- Light / Bulb / LED controller (RGB)
- Light / Bulb / LED controller (RGBW)
- IR Bridge
- RF Bridge
Virtual Device - A Virtual Device uses a RF/IR bridge to control your RF/IR devices or receive device’s state
- Virtual Contact Sensor - Add RF contact sensor as SmartThings contact sensor
- Virtual Motion Sensor - Add RF contact sensor as SmartThings motion sensor
(#) Not Available Yet
Installation:
- Use the following link to enroll in the channel and install the driver on your hub:
Invite link: https://bestow-regional.api.smartthings.com/invite/d4291roPPD2o
Driver Name: Tasmota Edge
- Go to your SmartThings app, under “Add devices”, and do a “Scan for nearby devices”
This will add a new device called Tasmota Edge. - Open the Tasmota Edge device, select the device you want to create, and the device will be created.
- Open the newly created device, under “Settings”, fill in the Tasmota device IP address and access other features.
- Tasmota web password is currently not supported
If your device is currently using the Tasmota (Connect) Groovy SmartApp/Driver, you MUST remove the device from Tasmota (Connect), and then add it using Tasmota Edge.
Tasmota Edge is free for all of up to 5 Tasmota devices. It includes all features and future updates.
For users of 5+ Tasmota devices, a one-time USD$20 contribution is needed for each Hub. This includes unlimited Tasmota devices, all features and future updates.
Please contribute via this PayPal link, and DM (or email hello@awfullysmart.com
) your Hub ID to get the key to unlock unlimited Tasmota devices. Please allow us some time to respond with the key.
The Hub ID can be found in the Tasmota Edge device (screenshot below).
Screenshots:
Tasmota Edge Device - Add new Tasmota supported device here
Fan, Metering Switch, Switch, TH (Temperature-Humidity) Switch
Light / Bulb / LED controller - RGBW, RGB, CCT, Dimmer
RF Bridge, IR Bridge, Virtual Motion Sensor, Virtual Contact Sensor
A Virtual Device uses a RF/IR bridge to control your RF/IR devices or receive device’s state.
