Someone has added my device to thier smartthings hub
Someone has added my devices to their Snartthings and wont disconnect them. Is there some way i can remove them myself without access to the hub?
How did that happen? Do you live in an apartment/condo and someone else’s hub found them? I’m curious!
Anyway, you can reset the devices. Depending on the device there are certain processes to follow.
If it’s a zwave device, perform a General Exclude from your hub and follow the instructions for your device on how to exclude. For a switch, it usually just requires tapping on either the on of off part of the switch.
Some Zigbee devices, like ST’s, require that you just hold a button down on the device for X seconds, or tap on the button 5, 7, or x number of times. GE zigbee switches just require that you tap on the upper paddle 10 times.
It all depends on the device, so look up your user guides to figure each one out.
Yes, reset the device and re-pair it to your hub
Which devices specifically? Also did you open a support ticket?
Its not actually my devices that have been mucked around with. My friend had a nasty break up with their partner, all the devices including kids tables and phones were commecđ to the home hub. Now the partner will not disconnect them.
Should be the same basic advice. If your friend has physical access To the Devices they want to disconnect, they can just individually reset each device. Then it will no longer be connected to that smartthings hub.
Since you were talking about tablets as well, I am assuming that it’s a smartthings Wi-Fi mesh system? It’s still the same answer. Any device that they have physical access to can be individually reset.
Yikes! That does not sound like fun at all. Sorry to hear about that.
Literally having the exact same problem. My pc says i can’t change some settings bc it’s being controlled by a smart things app. It is the most insane thing to live through when you have bet little knowledge on technology. Did she get everything unpaired? I still haven’t figured out how to do it.
Can you provide the community with more details to get a clearer picture of your issue? Provide screenshots when possible. On the PC, where are you seeing this issue? The ST app, CLI or online Advanced Web App? What device are you attempting to remove… brand/model?
Doubt your post is related to this thread as it was dealing with a different issue… plus it is an old thread :slight_smile: but no problem, someone will try to assist.
