I’ve purchased another hub, not Smartthings, I’m going to be moving most or all of my devices to. Does it make any difference if I delete them from Smartthings before I do a reset on the device, or after?
Thanks,
Jon
Thanks,
Jon
In the past I have manually removed them devices from the App or IDE (without first resetting them) , and then re-added them by pressing their reset buttons (or what ever method they require) and that works, so I would imagine this should do the trick when moving them to a new hub.
If you’re going to keep running SmartThings hub with some devices for a while, I think you’d have best results by using the SmartThings app to delete the device first. Then do a factory reset on the device.
You can also delete the device from SmartThings using the app after the device has been reset but you’ll have to do a “force delete”.
It’s cleaner if you remove them via smartthings first, but it shouldn’t be necessary.
If they are Z wave devices and you don’t remove them via smartthings then you will probably have to do a general exclusion before adding them to your new Z wave hub.
Thanks all, I thought it was probably made sense to remove devices from Smartthings first, but wasn’t sure. This is probably a good idea in most pairings with hubs, phones, etc but as I don’t do this type of thing often it’s nice to have some confirmation.
I am the inquisitive type. Why are you moving away from SmartThings and to what platform are you migrating to?
I’m trying out Hubitat. Local execution and (allegedly) more complex automations are what attracted me. Still way to early to decide if one is better than the other though.
