Bought the OSRAM LIGHTIFY SWITCH on Amazon in Germany to use with ST. Didn’t work, just shows up as a greyed out “Thing”. Community said it probably couldn’t be done.
I grabbed a Zigbee example code from ST and tweaked it just a little bit and now my switch works. Wanted to share. Disclaimer: I have not coded in 20 years, I have no idea how the Zigbee protocol works, and I have no clue about the ST API. So I have no doubt that the code here is bonkers. Maybe someone who actually knows this stuff should clean it up
* Copyright 2015 SmartThings
* Adapted by Michael Seifert for the Osram Switch (NOT the dimmer).
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
// definition (name: "ZigBee Dimmer", namespace: "smartthings", author: "SmartThings") {
definition (name: "ZigBee Switch", namespace: "smartthings", author: "Seifert") {
capability "Actuator"
capability "Configuration"
capability "Refresh"
capability "Switch"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B04, FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY SWITCH ON/OFF", deviceJoinName: "OSRAM LIGHTIFY SWITCH"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, FF00", outClusters: "0019", manufacturer: "MRVL", model: "MZ100", deviceJoinName: "Wemo Bulb"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05", outClusters: "0019", manufacturer: "OSRAM SYLVANIA", model: "iQBR30", deviceJoinName: "Sylvania Ultra iQ"
tiles(scale: 2) {
multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#79b821", nextState:"turningOff"
attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#79b821", nextState:"turningOff"
attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
main "switch"
details(["switch", "refresh"])
// Parse incoming device messages to generate events
log.debug "description is $description"
def event = zigbee.getEvent(description)
if (event) {
sendEvent(event)
else {
log.warn "DID NOT PARSE MESSAGE for description : $description"
log.debug zigbee.parseDescriptionAsMap(description)
def off() {
zigbee.off()
def on() {
zigbee.on()
def refresh() {
return zigbee.readAttribute(0x0006, 0x0000) +
zigbee.readAttribute(0x0008, 0x0000) +
zigbee.configureReporting(0x0006, 0x0000, 0x10, 0, 600, null) +
zigbee.configureReporting(0x0008, 0x0000, 0x20, 1, 3600, 0x01)
def configure() {
log.debug "Configuring Reporting and Bindings."
return zigbee.configureReporting(0x0006, 0x0000, 0x10, 0, 600, null) +
zigbee.configureReporting(0x0008, 0x0000, 0x20, 1, 3600, 0x01) +
