[SOLVED] Corrupt Scenes
I’m running into a scenario where 3 scenes that were previously created somehow got corrupted. If I click on them in the app, they run. However when I try to edit them all I get is a white screen which then fails back to the scene tab. I can create and edit new scenes but can’t edit or delete the corrupted ones.
Has anybody run into this issue and have you found a fix or way to perform a manual deletion? I’ve tested on multiple phones with the same symptoms and I’ve reinstalled the app as well as rebooted the hub.
Scenes are listed in the IDE under the My Locations / Show Location / Scenes page. You can delete them there.
e.g. https://graph.api.smartthings.com/location/scenes
But don’t start at graph.api; use https://account.SmartThings.com to login, and navigate to My Locations etc.
Thanks, that fixed my issue! I was poking around in graph.api for awhile and couldn’t locate them.
