i need help deleting two scenes. they will not go away…
So, you haven’t had any luck?
I am tagging @Brad_ST, he might can help remove those stuck Scenes.
Can you delete them from the mobile app? The Scenes list in the IDE was fixed this week for displaying scenes but I don’t think deletes work.
very good news!
the scenes are already seen in IDE
Thank you
they don’t appear in the mobile app were you can create and delete them. but the do appear in the scenes on the dashboard…
@Brad_ST can someone edit my account on the server to remove them? since ST is b#%$e!
i think ST techs need a “clean” utility to fix accounts…
it says it is deleted, but it isn’t…
They’ve been deleted.
wOOt
what was the issue?
If you weren’t seeing them in the app then I’m guessing they failed to migrate from an older version of scenes. That’s usually due to the scene containing devices that are deleted.
plausible… but they did show on dashboard only…
I’m having this exact issue. I want to delete my “Good Night!” scene but have run into the exact same problem. Can someone help me? Thanks.
Any fix for this yet… I don’t see 2 scenes in the new app, but they show up in the widget and Apple Watch. I can tell which they are buy the icons. where is that photo above from? I dont see a place for scenes when I log into https://graph.api.smartthings.com
Click on My Locations, then Home.
At the bottom of the page there is a List Scenes link.
thanks, found them, but they dont seem to delete?
