SOLVED: Bye, Wink: Now how can I get the Wink door sensors working with my Aeotec hub?
Disclaimer: I’m not very tech savvy so be gentle.
Hub works fine with my lights, but not the original Wink door sensors. I’ve done the z exclusion, factory reset and removed/replaced the batteries. Aeotec help says “Most Wink devices as long as they’re zigbee or Z-Wave should work with Smart Home Hub”
Any ideas? Thanks.
see if this faq page helps…
Feel free to respond back if you were successful or not :slight_smile:
Thanks. Should have mentioned I did read that FAQ in my OP
I want to set up an automation so that when the front door is opened between 5-11p, two lights turn on and then shut off after 3-5 mins
Welcome! What’s the model number of the sensors?
At the bottom it says
MC-V8.0
20160315 E/U
At the top
R18
R16
C9
I bought the Wink Lookout system in 2018
Try using the factory reset procedure on the contact sensors, and then try pairing these z-wave devices.
Tried the instructions in red, hub still doesn’t recognize the Wink sensors :confused:
EDIT 1130am: front door sensor is on hub and working
THANK YOU
EDIT 3p can’t get back door sensor to pair
Heard back from Aeotec, here’s how to pair all Wink devices with ST/Aeotec hub 1/2
Part 2/2
