Great thread! I learned a lot by reading this.
Question: can the fibaro controller work with the philips hue hub? can i add this to my existing hue setup?
Unfortunately not on its own
The hue bridge is not a full home automation controller and uses the Zigbee protocol rather than Z-wave which the Fibaro uses.
We are using the smartthings hub to control these which is capable of both protocols.
thanks for the thread
i have read and tried this maybe im missing something
but i can not figure out how to get the rgbw to set a colour when motion is detected
what i want is button/motion to turn on lights whith whichever colour i set for that time of day
or alternativley
button to sett normally white and a routine called bathtime to set a colour at a preset level
any clues fellas ?
You are a little bit vague Gareth, when you say button do you mean a button in St like a virtual switch or do you mean a real physical button ??
If you can give us the use case scenario maybe we can understand what you see as the obvious, i just cant get my hear round what you want need
Apologies.
I have the controller and a physical button or a motion sensor. Ie:not virtual.
But when it triggers or is pressed it will not set the colour.
Ideally what I want is to have white when motion or button is pressed.
And a routine to set it as colour.
Hope this helps
Gareth
if you just want the RGBW to respond to a switch and give you a certain colour then you can try this smartapp:
https://github.com/CobraVmax/SmartThings/tree/master/smartapps/cobra/fibaro-colour-switch.src
and in case you need help installing, have a look here:
An alternative would be to use webcore:
ta i had just installed that code, so will play now and see what i can achieve
thanks
Gareth
This app was written to use the following DHT for the Fibaro.
yep alredy playing with that
just needed it to trigger colours when a switch or motion was senced.
time to play
There are a couple of apps I have written for the Fibaro using this DTH.
Have a look here when you have finished playing with that one
i think i have intalled all of yours now. but simple steps first. routine for the good ladies bathtime would be good, them i can kit out the kids bedrooms etc etc etc ooo will the fun ever stop
I hadn’t thought about Kids’ bedrooms…
I wonder if I could write one to dim over a period of time… i.e start at one level of brightness then dim and finally off over a few minutes…
That might be fun
i like the idea of a on when they walk in, then dim down to turn off when it is sleeping time
i have them set to go off on the main bulb at a certain time but a wind down would be great
or alternatively a “WAKE” up when it gets to a set time, set police flashing or storm lol
I have something similar I wrote for my Kitchen lights (not fibaro)
When you walk into the room they are on 100% and the plinth white leds come on…
After motion stops the plinth lights go off but the Hue bulbs go down to 20% to give a warm glow
The fun stops when you try to add a new lighting routine whilst the mrs is yapping at you… you accidentally hit "remove " at the bottom in red and then in a panick to save your complicated routines hit “remove” again in the confirmation box !!!
Aaarrggghhhhhh
qu: this app doesnt show all of my switchs or contacts ?
i have a zwave door switch but it doesn’t show up ?
Gareth did you get this working for you?
Which switches/contacts don’t show up and in which section/app?
Apologies for going off topic, but has anybody tried using the Fibaro RGBW module on the Hue extension strip. I have a spare 2m extension strip and this might be a way to utilise it.
Hi @Cobra
I believe that I have successfully installed the DTH, but I am not 100% sure. Is there anyway to check this?
I followed the instructions on this link , but I am not confident about “Part Three” step “4”
When I select from the drop down menu, there are 2 options with the exact same name.
In my ST app, I now see these options
which i believe (but i am not sure) were not there before.
Is there any way to check if I have done this correctly?
The fibaro should be able to use any RGBW strip providing the voltage is 12-24v dc if you can connect it
You might need to swap,wires around to get the colours to match
