I have a n00b question… How do I get multiple dashboards? I read that I’d have to install it via the IDE? Do I create a new app using the code from Github? (via My SmartApps --> New SmartApp --> From Code?)
SmartTiles code is currently unavailable, so new “multiple dashboards” are not available.
I asked SmartThings to change my email address. Now my existing dashboards won’t work and I can’t get new URLs for them. Is there a way to fix this without making new dashboards?
Sorry if I’m dumb, but I can’t find any how to on changing themes. Could someone point me at a link? All I’ve found is:
Custom Theme
If you want to change the style, I added a block of code for your custom CSS overrides. Add your style within customCSS() method. I will always keep it at the end of the SmartApp.
This is a bit brief for someone who isn’t handy with CSS. I see screenshots of various themes that already exist, and I have to admit all of them look better than the default to me. How can I invoke one of them?
And I found it. Duh.
HI naq90,
Can you please provide instructions on how you created the play/pause buttons. I am able to get Spotify to launch but not play a playlist automatically. Any help is much appreciated.
Anyone notice that Device Order is not working anymore after you add a device?
When a new device is added, it should go to the beginning of the list. Then you should be able to rearrange the tiles. If that’s not the case, let me know.
Has anyone done a customization for the GE Fan 12730 to make the tile a toggle that you can choose your speed instead of using the dimmer slider?
Have not tried yet as I don’t have the switches. I am on the fence with the 12730 because all my fans have a light kit. I would like to be able to still have control of the light. My first thought was a Creee bulb but I am not it will work.
The device type works in smartthings app. I was looking to make a tile act similarly.
As for the switch itself, it currently has a low WAF because the poor indication of what speed you are on and how to increase/decease the speed. she hates it and I was hoping to improve with a smarttiles button.
That’s correct Alex, it does go the beginning but when I try to rearrange using the Rearrange/Reorder option in the Smart app I get an empty page.
Also when I click on Events History in the dashboard I get the following error: (it spins a little first)
{“error”:true,“type”:“java.lang.reflect.UndeclaredThrowableException”,“message”:“An unexpected error occurred.”}
Do you have “too many” devices? Looks like it’s just crapping out due to timeout.
60 odd icons (each device would have a few icons) on the dashboard?
Try again? 20 chars.
Yes I tried again just now it spins for a second and then almost instanenously it shows a blank page. (this is Device Order).
The event viewer is still showing the error
Did you try removing the last device that you added?
Just tried it, removed the last device, still same issue, event history gives an error and device order shows a blank page.
@RBoy, which version are you using and which device is causing you grief?
The latest version 5.4.2 I think (I don’t see in my Apps just on the phone so I’m assuming you’ve pushed it to the account).
The recently added device was a garage door opener. But even after I remove it I’m still seeing the issue.
