SmartThings Smart Plug 2019 x3 keep powering off/on every couple of minutes
Ive been a long term user and am actually still using a V1 Kickstarter hub - dont let that stop you reading, or say that (might be) the problem!
So I bought a few extra Smart Plugs 2019 the other day (in addition to some 2017 versions). These paired with the hub fine, and (I believe) worked without problem for about 12 hours.
What Im now seeing is that they power off and on every couple of minutes (from the on position). From the off position, they dont power on, but do generate “configure” COMMANDS.
Im trying to diagnose if they did work ok for 12 hours (possibly after which they had a firmware update), by trialling an unpaired device; and/or whether its something to do with ‘warming up’ as I sometimes see they are ok for about 10-15 minutes before exhibiting the problem.
Here are some logs:
From OFF position -
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:12:34 PM: debug description is catchall: 0104 0006 01 01 0140 00 23CA 00 00 0000 01 01 0000001000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:12:33 PM: debug Parse returned [name:energy, value:0, unit:kWh, linkText:Smart Plug 1, descriptionText:Smart Plug 1 energy is 0 kWh, isStateChange:false, displayed:false]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:12:33 PM: debug energy
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:12:33 PM: debug Desc Map: [raw:23CA01070212000025000000000000, dni:23CA, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, value:000000000000, isValidForDataType:true, clusterInt:1794, attrInt:0]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:12:33 PM: debug description is read attr - raw: 23CA01070212000025000000000000, dni: 23CA, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, value: 000000000000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:12:33 PM: info event outer:[name:switch, value:off]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:12:33 PM: info event enter:[name:switch, value:off]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:12:33 PM: debug description is on/off: 0
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:35 PM: debug power (0B04) capability configured successfully
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:35 PM: debug description is catchall: 0104 0B04 01 01 0140 00 23CA 00 00 0000 07 01 00
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:31 PM: debug Parse returned [:]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:31 PM: debug Desc Map: [raw:0104 0702 01 01 0140 00 23CA 00 00 0000 07 01 00, profileId:0104, clusterId:0702, sourceEndpoint:01, destinationEndpoint:01, options:0140, messageType:00, dni:23CA, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00], clusterInt:1794, commandInt:7]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:31 PM: debug power (0702) capability configured successfully
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:31 PM: debug description is catchall: 0104 0702 01 01 0140 00 23CA 00 00 0000 07 01 00
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:26 PM: debug Parse returned [:]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:26 PM: debug Desc Map: [raw:0104 0006 01 01 0140 00 23CA 00 00 0000 07 01 00, profileId:0104, clusterId:0006, sourceEndpoint:01, destinationEndpoint:01, options:0140, messageType:00, dni:23CA, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00], clusterInt:6, commandInt:7]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:26 PM: debug description is catchall: 0104 0006 01 01 0140 00 23CA 00 00 0000 07 01 00
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:22 PM: debug Parse returned [name:energy, value:0, unit:kWh, linkText:Smart Plug 1, descriptionText:Smart Plug 1 energy is 0 kWh, isStateChange:false, displayed:false]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:22 PM: debug energy
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:22 PM: debug Desc Map: [raw:23CA0107021400000025000000000000, dni:23CA, endpoint:01, cluster:0702, size:14, attrId:0000, result:success, encoding:25, value:000000000000, isValidForDataType:true, clusterInt:1794, attrInt:0]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:22 PM: debug description is read attr - raw: 23CA0107021400000025000000000000, dni: 23CA, endpoint: 01, cluster: 0702, size: 14, attrId: 0000, result: success, encoding: 25, value: 000000000000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:20 PM: info event outer:[name:power, value:0, unit:W]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:20 PM: info event enter:[name:power, value:0]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:20 PM: debug description is read attr - raw: 23CA010B040C0B0500290000, dni: 23CA, endpoint: 01, cluster: 0B04, size: 0C, attrId: 050b, result: success, encoding: 29, value: 0000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:18 PM: debug description is catchall: 0104 0006 01 01 0140 00 23CA 00 00 0000 01 01 0000001000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:18 PM: debug refresh
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:18 PM: debug Configuring Reporting
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:18 PM: info event outer:[name:switch, value:off]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:18 PM: info event enter:[name:switch, value:off]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:18 PM: debug description is on/off: 0
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:17 PM: info event outer:[name:power, value:0, unit:W]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:17 PM: info event enter:[name:power, value:0]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:17 PM: debug description is read attr - raw: 23CA010B040A0B05290000, dni: 23CA, endpoint: 01, cluster: 0B04, size: 0A, attrId: 050b, encoding: 29, value: 0000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:17 PM: debug Parse returned [name:energy, value:0, unit:kWh, linkText:Smart Plug 1, descriptionText:Smart Plug 1 energy is 0 kWh, isStateChange:false, displayed:false]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:17 PM: debug energy
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:17 PM: debug Desc Map: [raw:23CA01070212000025000000000000, dni:23CA, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, value:000000000000, isValidForDataType:true, clusterInt:1794, attrInt:0]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:11:17 PM: debug description is read attr - raw: 23CA01070212000025000000000000, dni: 23CA, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, value: 000000000000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:50 PM: debug Parse returned [:]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:50 PM: debug Desc Map: [raw:0104 0B04 01 01 0140 00 23CA 00 00 0000 07 01 00, profileId:0104, clusterId:0B04, sourceEndpoint:01, destinationEndpoint:01, options:0140, messageType:00, dni:23CA, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00], clusterInt:2820, commandInt:7]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:50 PM: debug power (0B04) capability configured successfully
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:50 PM: debug description is catchall: 0104 0B04 01 01 0140 00 23CA 00 00 0000 07 01 00
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:45 PM: debug Parse returned [:]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:45 PM: debug Desc Map: [raw:0104 0702 01 01 0140 00 23CA 00 00 0000 07 01 00, profileId:0104, clusterId:0702, sourceEndpoint:01, destinationEndpoint:01, options:0140, messageType:00, dni:23CA, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00], clusterInt:1794, commandInt:7]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:45 PM: debug power (0702) capability configured successfully
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:45 PM: debug description is catchall: 0104 0702 01 01 0140 00 23CA 00 00 0000 07 01 00
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:41 PM: debug Parse returned [:]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:41 PM: debug Desc Map: [raw:0104 0006 01 01 0140 00 23CA 00 00 0000 07 01 00, profileId:0104, clusterId:0006, sourceEndpoint:01, destinationEndpoint:01, options:0140, messageType:00, dni:23CA, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00], clusterInt:6, commandInt:7]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:41 PM: debug description is catchall: 0104 0006 01 01 0140 00 23CA 00 00 0000 07 01 00
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:37 PM: debug Parse returned [name:energy, value:0, unit:kWh, linkText:Smart Plug 1, descriptionText:Smart Plug 1 energy is 0 kWh, isStateChange:false, displayed:false]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:37 PM: debug energy
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:36 PM: info event outer:[name:power, value:0, unit:W]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:36 PM: info event enter:[name:power, value:0]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:36 PM: debug description is read attr - raw: 23CA010B040C0B0500290000, dni: 23CA, endpoint: 01, cluster: 0B04, size: 0C, attrId: 050b, result: success, encoding: 29, value: 0000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:33 PM: info event outer:[name:switch, value:off]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:33 PM: info event enter:[name:switch, value:off]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:33 PM: debug description is catchall: 0104 0006 01 01 0140 00 23CA 00 00 0000 01 01 0000001000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:32 PM: debug description is read attr - raw: 23CA010B040A0B05290000, dni: 23CA, endpoint: 01, cluster: 0B04, size: 0A, attrId: 050b, encoding: 29, value: 0000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:32 PM: debug Parse returned [name:energy, value:0, unit:kWh, linkText:Smart Plug 1, descriptionText:Smart Plug 1 energy is 0 kWh, isStateChange:false, displayed:false]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:32 PM: debug energy
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:32 PM: debug Desc Map: [raw:23CA01070212000025000000000000, dni:23CA, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, value:000000000000, isValidForDataType:true, clusterInt:1794, attrInt:0]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:07:32 PM: debug description is read attr - raw: 23CA01070212000025000000000000, dni: 23CA, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, value: 000000000000
[2019-09-10 1:11:18.346 PM BST *moments ago* ](https://graph.api.smartthings.com/device/4aa17066-f289-4e0a-bfe9-c933045af4ce/event/182242a0-d3c4-11e9-a4d9-0a65d77245de?all=true&source=&max=25) COMMAND configure configure command was sent to Smart Plug 1 true [2019-09-10 1:07:33.173 PM BST *moments ago* ](https://graph.api.smartthings.com/device/4aa17066-f289-4e0a-bfe9-c933045af4ce/event/91eb9651-d3c3-11e9-a4d9-0a65d77245de?all=true&source=&max=25) COMMAND configure configure command was sent to Smart Plug 1 true [2019-09-10 1:06:17.807 PM BST *5 minutes ago* ](https://graph.api.smartthings.com/device/4aa17066-f289-4e0a-bfe9-c933045af4ce/event/64ffa5f0-d3c3-11e9-aae5-0ab9efac0bf4?all=true&source=&max=25) COMMAND configure configure command was sent to Smart Plug 1 true [2019-09-10 1:06:08.537 PM BST *5 minutes ago* ](https://graph.api.smartthings.com/device/4aa17066-f289-4e0a-bfe9-c933045af4ce/event/5f792891-d3c3-11e9-9d88-0adc43659542?all=true&source=&max=25) COMMAND configure configure command was sent to Smart Plug 1 true [2019-09-10 1:04:14.381 PM BST *7 minutes ago* ](https://graph.api.smartthings.com/device/4aa17066-f289-4e0a-bfe9-c933045af4ce/event/1b6e55d0-d3c3-11e9-a4d9-0a65d77245de?all=true&source=&max=25) COMMAND configure configure command was sent to Smart Plug 1 true [2019-09-10 1:03:47.377 PM BST *8 minutes ago* ](https://graph.api.smartthings.com/device/4aa17066-f289-4e0a-bfe9-c933045af4ce/event/0b55da10-d3c3-11e9-b87c-12739dd7f206?all=true&source=&max=25) COMMAND configure configure command was sent to Smart Plug 1 true [2019-09-10 1:02:32.137 PM BST *9 minutes ago* ](https://graph.api.smartthings.com/device/4aa17066-f289-4e0a-bfe9-c933045af4ce/event/de7d2390-d3c2-11e9-b87c-12739dd7f206?all=true&source=&max=25) COMMAND configure configure command was sent to Smart Plug 1 true [2019-09-10 1:01:07.454 PM BST *10 minutes ago* ](https://graph.api.smartthings.com/device/4aa17066-f289-4e0a-bfe9-c933045af4ce/event/ac0389e0-d3c2-11e9-9d88-0adc43659542?all=true&source=&max=25) COMMAND configure configure command was sent to Smart Plug 1 true [2019-09-10 12:58:40.189 PM BST *13 minutes ago* ](https://graph.api.smartthings.com/device/4aa17066-f289-4e0a-bfe9-c933045af4ce/event/543cd5e0-d3c2-11e9-9550-126d43e66cea?all=true&source=&max=25) COMMAND configure configure command was sent to Smart Plug 1 true [2019-09-10 12:57:36.018 PM BST *14 minutes ago* ](https://graph.api.smartthings.com/device/4aa17066-f289-4e0a-bfe9-c933045af4ce/event/2dfcf720-d3c2-11e9-b8c1-12b2a020bdbe?all=true&source=&max=25) COMMAND
From the ON position:
[4aa17066-f289-4e0a-bfe9-c933045af4ce](https://graph.api.smartthings.com/ide/logs#4aa17066-f289-4e0a-bfe9-c933045af4ce) 1:42:54 PM: debug Parse returned [:]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:54 PM: debug Desc Map: [raw:0104 0B04 01 01 0140 00 23CA 00 00 0000 07 01 00, profileId:0104, clusterId:0B04, sourceEndpoint:01, destinationEndpoint:01, options:0140, messageType:00, dni:23CA, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00], clusterInt:2820, commandInt:7]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:54 PM: debug power (0B04) capability configured successfully
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:54 PM: debug description is catchall: 0104 0B04 01 01 0140 00 23CA 00 00 0000 07 01 00
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:50 PM: debug Parse returned [:]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:50 PM: debug Desc Map: [raw:0104 0702 01 01 0140 00 23CA 00 00 0000 07 01 00, profileId:0104, clusterId:0702, sourceEndpoint:01, destinationEndpoint:01, options:0140, messageType:00, dni:23CA, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00], clusterInt:1794, commandInt:7]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:50 PM: debug power (0702) capability configured successfully
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:50 PM: debug description is catchall: 0104 0702 01 01 0140 00 23CA 00 00 0000 07 01 00
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:46 PM: debug Parse returned [:]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:46 PM: debug Desc Map: [raw:0104 0006 01 01 0140 00 23CA 00 00 0000 07 01 00, profileId:0104, clusterId:0006, sourceEndpoint:01, destinationEndpoint:01, options:0140, messageType:00, dni:23CA, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00], clusterInt:6, commandInt:7]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:46 PM: debug description is catchall: 0104 0006 01 01 0140 00 23CA 00 00 0000 07 01 00
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:42 PM: debug Parse returned [name:energy, value:0, unit:kWh, linkText:Smart Plug 1, descriptionText:Smart Plug 1 energy is 0 kWh, isStateChange:false, displayed:false]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:42 PM: debug energy
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:42 PM: debug Desc Map: [raw:23CA0107021400000025000000000000, dni:23CA, endpoint:01, cluster:0702, size:14, attrId:0000, result:success, encoding:25, value:000000000000, isValidForDataType:true, clusterInt:1794, attrInt:0]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:42 PM: debug description is read attr - raw: 23CA0107021400000025000000000000, dni: 23CA, endpoint: 01, cluster: 0702, size: 14, attrId: 0000, result: success, encoding: 25, value: 000000000000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:40 PM: info event outer:[name:power, value:0, unit:W]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:40 PM: info event enter:[name:power, value:0]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:40 PM: debug description is read attr - raw: 23CA010B040C0B0500290000, dni: 23CA, endpoint: 01, cluster: 0B04, size: 0C, attrId: 050b, result: success, encoding: 29, value: 0000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:38 PM: info event outer:[name:switch, value:on]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:38 PM: info event enter:[name:switch, value:on]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:38 PM: debug description is catchall: 0104 0006 01 01 0140 00 23CA 00 00 0000 01 01 0000001001
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:37 PM: debug refresh
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:37 PM: debug Configuring Reporting
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:37 PM: info event outer:[name:switch, value:on]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:37 PM: info event enter:[name:switch, value:on]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:37 PM: debug description is on/off: 1
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:37 PM: info event outer:[name:switch, value:off]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:37 PM: info event enter:[name:switch, value:off]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:37 PM: debug description is on/off: 0
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:36 PM: info event outer:[name:power, value:0, unit:W]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:36 PM: info event enter:[name:power, value:0]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:36 PM: debug description is read attr - raw: 23CA010B040A0B05290000, dni: 23CA, endpoint: 01, cluster: 0B04, size: 0A, attrId: 050b, encoding: 29, value: 0000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:36 PM: debug Parse returned [name:energy, value:0, unit:kWh, linkText:Smart Plug 1, descriptionText:Smart Plug 1 energy is 0 kWh, isStateChange:false, displayed:false]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:36 PM: debug energy
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:36 PM: debug Desc Map: [raw:23CA01070212000025000000000000, dni:23CA, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, value:000000000000, isValidForDataType:true, clusterInt:1794, attrInt:0]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:42:36 PM: debug description is read attr - raw: 23CA01070212000025000000000000, dni: 23CA, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, value: 000000000000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:38:19 PM: info event outer:[name:switch, value:on]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:38:19 PM: info event enter:[name:switch, value:on]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:38:19 PM: debug description is on/off: 1
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:37:38 PM: info event outer:[name:power, value:0, unit:W]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:37:38 PM: info event enter:[name:power, value:0]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:37:38 PM: debug description is read attr - raw: 23CA010B040A0B05290000, dni: 23CA, endpoint: 01, cluster: 0B04, size: 0A, attrId: 050b, encoding: 29, value: 0000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:37:38 PM: debug Parse returned [name:energy, value:0, unit:kWh, linkText:Smart Plug 1, descriptionText:Smart Plug 1 energy is 0 kWh, isStateChange:false, displayed:false]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:37:38 PM: debug energy
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:37:38 PM: debug Desc Map: [raw:23CA01070212000025000000000000, dni:23CA, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, value:000000000000, isValidForDataType:true, clusterInt:1794, attrInt:0]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:37:38 PM: debug description is read attr - raw: 23CA01070212000025000000000000, dni: 23CA, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, value: 000000000000
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:28:16 PM: info event outer:[name:switch, value:on]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:28:16 PM: info event enter:[name:switch, value:on]
4aa17066-f289-4e0a-bfe9-c933045af4ce 1:28:16 PM: debug description is on/off: 1
How many plugs is this happening to, and are you using ST’s default DTH (nothing custom) for this type of device?
This may have to be something ST support may have to dig into a little deeper from their end too.
Its at least 2 out of 4.
I am cautiously experimenting with the other 2 - for example, I have not paired one, but have it switched on with lamp attached. Im ‘listening’ for the click of the relay which indicates it coming on/off, and I dont hear it which suggests the problem either caused by pairing or firmware.
Ive also ordered a V3 hub to pair the last one with, just in case it is my V1 :wink:
Im using the standard DTH, which does detect energy monitor as well as power monitor; I noticed that I couldnt reset energy usage, however.
Ive also tried some of the other presupplied DTH and they have the same problem.
Weird for sure. I didn’t see any device/smartapp sending commands to your device, other than the configure command from the hub. I’d be curious to see how these work on your v3 hub.
I had a couple of the smarplugs paired to the V3 hub.
I could see that there was actually a new version of FW for the plugs, which hadnt been applied by the V1 hub (Imnot sure it can actually do it…)
So I forced the firmware update and left the two plugs connected to the V3 hub overnight.
I didnt see any power on/off cycles…
So now Ive connected those two plugs back to the V1 hub and am monitoring…
