smartthing app - smart lighting toggle switch is off and will not stay toggled on.
If I start smartthings app… I see smart lighting (toggled off).
and then hit routines it sometimes displays my routines or I get There was a problem connecting. Try again later…
is this correct please should smart lighting toggle stay on or off
cheers
Chris
I’m having the same issue for months, intermittently. Turn it on and ignore the fact that it is turned off automatically. The routines work normally and after a day or so it is back on in the App
I have 5 hubs and this happens to one hub. I gave up with Smartlighting on the one hub and just set up Routines instead.
I have installed Smartthings android on an old phone and the same problem occurs.
The smart lighting switch stays off
This is really annoying as you cannot easily see/edit your routines.
If you haven’t already… you should contact ST support and submit app logs
