I’m thinking to buy a Samsung SmartThings Home Monitoring Kit, especially because I wanna use the two Samsung SmartThings Multipurpose Sensors with my home doors.
@Diego_M
I find the Smartthings door sensors to be VERY critical on how close the magnet is to show ‘Closed’ - they almost have to be touching.
I’m in the UK and use Z-Wave door sensors (Foxx or Aeon Labs) which I find can have quite a large gap before reporting as open so are more forgiving if the magnet is not so close to the sensor
If you are in the US (are at least using a US smartthings hub) I think there are other door sensors available that might work for you
I’m sure some Yank will come along with some advice soon…
I just measured the SmartThings Multisensor here in the US: it will show open/close when the gap between the sensor and the magnet is less than 1/2 inch if they are at the same level and 1/4 inch if the magnet is higher or lower.
