SmartThings Motion Sensor Batteries - No Energizer!
Panasonic has a document for each type showing the different sub models. They are easiest to find on digikey’s site, here’s an example of the 2032’s:
http://industrial.panasonic.com/cdbs/www-data/pdf2/AAA4000/AAA4000DE87.pdf
It was taken from this page:
https://www.digikey.com/product-detail/en/panasonic-bsg/CR-2032-HF1N/P658-ND/2404063
And their pretty exhaustive, except for the sub models, lithium handbook:
Termination Style should be Pressure on Arrow’s site vs pc pins or anything else really. And it shouldn’t mention “surface mount” or “through hole”.
Hi there, thanks for this, I had the same problem as I got the energizers and couldn’t get it to re-detect. I’m kind of persistent though and don’t like the idea of being locked into a particular brand of something that is supposed to be universal by specification.
I have heavily modified my smart things motion detector using the latest in space age technology and it now works with the energizers. I took a starbucks double shot can, used a knife to cut a small sliver of aluminum out of it. I then scraped the aluminum with the knife to remove the food grade coating so it was bare metal. I then tucked that little bit of foil behind the metal contact on the side of the battery enclosure and left the length of it poking up and bent backwards over the top. I used a tiny piece of masking tape on the side of the battery to protect it from shorting by having the side skirts of the battery so high. Then I put the battery in and it works now.
Picture is here https://imgur.com/a/t3r4e
Can you please post a picture of the motion sensor without a battery so we can see how you modified the terminals?
Michael wich model 2450 from Arrow, they only seem to have one available and two others for quotes.
This may help you. These are the ones that I got. I ordered the 2450s from arrow.com and this is my invoice.
Thank you guys! Very helpful. I was thinking that my motion sensor was dead.
Obviously I have now a bunch of energizer I WANT and DID use, so I wanted to share this little hack.
I just made a small spacer of aluminum foil, then I laid it flat on the side contact, making sure that when I insert the battery it will not short it to the bottom.
And then popped in the battery. Working as a charm!
IMG_2445
Wanted to order some CR2477 from Arrow, but you can’t just order them, you have to get a quote. Strange, since all their other Panasonic are available.
For my two, i opened it up and carefully (while holding the pin on the board so it doesn’t come off) bent the pin into an “L” shape using just my fingers. Suggest using needle nose pliers if you have them laying around though.
It’s enough to make the contact work.
Okay, just bought a big box of Energizers and none seemed to work. Did a search and found this thread. Arrrrrrgh!
Yes, this is true, the newer Motion sensors do not have this brand requirement for battery.
However, the new sensor is also utterly useless, and doesn’t sense me until I’m about 1m or less from it.
The original version is much better. I did mistakenly buy a different brand than the sensor mentioned and as my punishment, they didn’t work. Putting in Duracell ones and they worked straight away.
this may be a help to other UK users, i’m currently using these:
and they work fine in my motion sensor. Also working in my multi purpose sensor but that has been modified after i snapped one of the contacts trying to use incorrect batteries - so i can’t confirm if it will work with a standard one.
Lots of talk about arrow.com, but they don’t have any Panasonic CR2450s in stock. Is this the correct one:
https://www.arrow.com/en/products/cr2450/panasonic
Thank you. Thank yoy very much indeed, I was becoming nuts with this.
I read the Notice saying only Panasonic or Duracel which seemed ridiculous to me so I bought Energizer and it worked in every sensor but in the motion sensor.
Obvioulsy I blamed the sensor.
Now everything makes sense to me.
It certainly does!! Thank you! I tried a few things lifting the metal connect, wedging slightly up with a bit of paper on one side…
I bought a pack of 10 of energizers a while back now I can use them! (The they are usually cheaper on amazon for some reasons)
Now hope the actual motion sensor does not die (have two serving as temperature sensor only) and that it reports battery life on ST properly as the batteries always report 60%ish when they just suddenly disconnect. It’s always the actual battery as it seems to be out of juice with reset light doesn’t even come on!
Thanks again
After burning tons of “Panasonic” batteries from Aliexpress I followed your guide to fix that British design on my 2015 motion sensors. On most sensors external battery works great but one sensor flashes orange light occasionally.
Anybody knows what orange light means?
When I connect extra battery I see green light just like when I put fresh Panasonic battery and then orange light comes up briefly.
