I have two smartthings multi sensors which are situated on external doors, I also have two motion sensors, one which is used to automatically turn on a light bulb in the hallway. On a daily basis I have to pull the Duracell battery (new and recently replaced) out of one of these sensors in order for it to start to communicate with the hub again. It is extremely frustrating to have to do this, the sensors are not very far away from the hub and thin walls separate them.
After the two recent firmware updates which have been pushed to the hub, I have had to (re)pair all Smarthings sensors (Motion and Multi Sensor) as they stop communicating with the hub.
I have contacted support which suggest moving the location of the hub away from the main router. This I did and things appeared to be ok for about two weeks with the sensors not disconnecting . I removed and paired them to start afresh. However, I now have to pull the battery out of the Front Door Multi sensor and Stairs motion sensors on a daily basis.
I am quickly losing the acceptance factor from the rest of the family as they warn of intrusion and turn on light bulbs. I do not trust the intrusion detection alerts I get from the front door sensor (it stops communicating in an open state usually in the early hours of the morning).
However, only the Smarthings sensors are experiencing these issues. I purchased a Xiaomi Motion Sensor, and added this device in February, it has not disconnected or had to be (re)paired to the hub. The Smarthings power outlet I have also works flawlessly.
Does anyone have any suggestion as to what could be the cause of the problem. I am wondering if the sensors are faulty, the hub and sensors were a gift so I am unable to return them. I have ordered a Xiaomi door sensor to test if they have the same problem.
I have been experiencing this issue too.
Some official Samsung sensors, and zwave bulbs show disconnected in the new ST app.
All automations still work ( if motion sensor shows disconnected, lights still turn on with motion)
They show online and working in ST Classic.
They show online and working in IDE
THERE IS AN EASY WAY TO GET THEM SHOWING CONNECTED IN THE NEW APP:
pull the sensor battery for 10 seconds. (or turn off power to the bulb for 10 seconds)
