new update out today
GREAT! It comes with all of the new features they just released in the Android app yesterday. Especially the Automation Categories! BUT, I canāt collapse the Rooms in the All Devices view like I can on Android.
The icon indicating that the routine runs locally now clearly visible on the routine tile.
Nice to go back to simple page swiping to look through devices.
Deleting a device now has another sequence which is not āEditā but 3 dots/Remove Device /select /confirm. Improvementā¦? At least now not possible to delete a hub from the main screen ![]()
Where did the settings go for widget?
Widget clicks now run without opening the app
Seems that the Routine category has a limit. When I attempt to add a bunch (10+) lighting routines I get āNo network connection. Connect to a network and try againā error. It also appears to include the Smart Lighting items at the bottom.
I have observed the same.
If you tap and hold the widget you get another menu and you can add routines to the widget.
Thank you. That resolved my issue.
