Just got a new SmartThings hub yesterday. Was an Iris user. I am seeing an issue where the Hub won’t power on (no light) when plugged into some outlets in my house. Others it works just fine. I am not using a power strip, plugging directly into the outlet. Anyone else see this issue???
Which model hub? And what country are you in?
Possibly a switched outlet?.. how old is the home?
It used to be a standard to have one side or both sides of a duplex outlet in each room controlled by a switch for table lamps.
Alternatively, perhaps one side of the duplex is bad.
There is no reason it would not work otherwise… with the exception stated by JD.
As others have said, a switched outlet would be the first thing to check. Perhaps your outlets aren’t getting power because an upstream GFI breaker has tripped. If you have an electrical sniffer that is the first place to look.
If some low current devices work, but others like your hub and lamps do not, I would be concerned that there may be a more dangerous condition such as a floating (disconnected/broken) neutral.
First thing I would do is plug in a lamp (non-LED) and see if those outlets work for it.
^^^This
As others said, you may have a problem with your outlets. But also could it be the jack on your hub not making contact? That may give you the impression that it’s the outlet, when it is the hub not powering on.
This is happening to me too. At this point I’m thinking it’s a faulty power supply. To rule out local wiring I plugged it into two different battery backup systems I have. Worked in one, and not the other. It’s also inconsistent over time in which wall plug it will work in.
I also just ran into this problem. Seven years of the hub no issues. Battery backup failed last night and now the Smartthings hub power supply doesn’t work on that circuit. It works on all others in the house. Hate to say this electrical engineer is baffled.
I would bet that the solder connecting one of the spades to the circuit board in the power supply is cracked or the pad has lifted off the board. Whether the supply powers up is dependent on the angle that the socket flexes the spade. This happens all the time in high amperage circuits in cars - power supply pins on the antilock brake modules do this frequently for instance.
If you try to source a replacement supply make sure it matches the specs of the original one exactly - there are lots of stories of people frying hubs using the wrong voltage as apparently the regulation circuit in the hub is inadequate or nonexistent.
