That is good news! Really quite an interesting product at a decent price.
I moved the technical discussion of thread networks to its own topic:
So the station is basically the same as a hub v3 but without z wave? And you cannot do hub 2 hub?
Am I missing anything? So for most people it will be able to do most of what the hub v3 does?
And it has thread?
Is it a more powerful processor?
It’s an inexpensive ($60), stripped down version of the V3 that also has a phone charger on top of it. It has thread, Zigbee, and WiFi, but no zwave. And it has galaxy find capabilities, and a nice scene button.
I still think it’s primarily intended for people who have a Samsung smart television or appliance and a Galaxy phone but no hub and want to start adding matter devices. But they haven’t said that officially.
You can include devices from both a v2/v3/Aeotec and the new Station hub in the same routine. It’s just that the Routine will have to run in the cloud vs locally. Same as hub->hub today.
Didn’t the article from the Verge say that Samsung said the hub will NOT be able to talk to other hubs even through Matter?
Matter over thread is supposed to share boarder routers, but I thought because of how Samsung was implementing it, this was already understand to be a no deal. If they allow their hubs to combine with Matter\Thread why not allow combining with say, Echo Hubs through Matter\Thread. Otherwise, what’s the point. All this Matter\Thread stuff just becomes another thing to add to Zwave, ZigBee.
Can WiFi devices connect directly to this Station Hub, or do they have to go through your WiFi router?
The hubs don’t talk directly to each other, but they both talk to the cloud, so you can have them both on the same account.
From the verge article:
The good news is that you can run multiple SmartThings hubs, so if you started with the Station and then decided you did want to add Z-Wave, you could integrate an Aeotec hub into your setup. But Samsung told me that for entirely local automations, all devices involved must be on the same hub. If your devices are on different hubs, the automations on them will run in the cloud.
Also, it’s really important to understand that a “matter controller” is not necessarily in matter terminology considered a “matter device.“
You will not be able to use a Google nest home smart speaker to control an echo smart speaker, for example. Both are matter controllers, neither is a controllable “matter device.”
Same for the smartthings hubs. They are matter controllers, but not matter devices.
As far as the point, there are several top goals for the matter standard:
let customers choose whatever app they want to use (that is matter compatible), and make it easy to add matter certified devices to that app. And to multiple apps.
simplify the onboarding process so that it basically works like HomeKit: scan a QR code, and you’re done
use more secure Wi-Fi for local communications from the matter certified devices to the matter controller. (Not to each other.)
All three of these are a big advantage over the current situation./Consumers should be able to select a device based on the logo on the box and know that it will work at their house whether their preferred voice assistant is Alexa, Google, or Siri. And whether their preferred app is Apple home or smartthings or IKEA.
Will automations run local if Matter wifi devices are part of the equation? Those devices connect to a router instead of a hub but are they treated no differently than devices that are connected to another ST hub?
Theoretically they should work the way the local LAN integration with the hue bridge works now. That is, the matter Wi-Fi device will be eligible to run locally, but after that, it depends on exactly what is in the routine. For example, if you are including it in a scene, that would probably require the cloud, because most scenes require the cloud. But we are just going to have to wait and see.
I’m just thinking about simple routines like motion sensor turns on a light there when motion is detected. As long as stuff like that still works locally than I’ll be happy.
Just too bad I’ll have to buy a couple new hubs(for Switchbot and Yolink) to ensure my current devices work with everything else and locally.
yes, Routines using Matter devices run local (if all the devices in the routine are connected to the same SmartThings hub)
And don’t involve any of the following:
- Scenes
- Lighting Groups
- Member Location
- Devices from cloud->cloud integrations
- Notification actions
- Weather triggers
- STHM triggers and actions
- Any Day time precondition
- Cloud virtual devices
Yeah, all of the other fine print for local routines also applies
My Station received a firmware update about 13 hours ago. It’s now on 46.8. The V2 and V3/Aeotec are on 46.10.
I just noticed my hub-connected devices paired to the Station do not show in the Groovy IDE at all (not even with Type = Placeholder).
Do they show at
Yes they do
Hi @Automated_House,
Could you share some pictures of ST Station in the ST app ?
Can it show some status information when is charging (iOS Devices)?
Can iOS users use charging states as triggers ?
Can it shows power consumption or some energy information in energy smartapp?
Thanks in advance.
