Smartthings Hub Not Connecting - Going to need to replace
There is a newer hub but it does not support z-wave.
Back to your current hub situation… some questions:
  • have you tried a different ethernet cable?
  • tried plugging into a different port of switch or router?
  • if connected to switch, have you tried a port on the router if available?
  • have you rebooted the router?
  • have you made any recent changes to your network?
  • have powered down the ST hub and removed batteries if using?
  • booted up ST hub with no batteries?
