Hi all,
I need your help regarding of my SmartThings hub v3 (firmware 031.00004) that repeatedly disconnecting and connecting back over and over again from 1st September.
I already contacted support team twice. First request was routed to wrong team and from second I still did not get any response.
I also did some investigation but didn’t find anything related to this issue. My ISP confirmed that internet connection is OK and stable (80Mbit/s download, 10Mbit/s upload and ping 23).
I also changed all nw cables to new “CAT6” and did router reset as well but still the same issue.
Sometimes SmartThings is running without any disconnection few hours but sometimes it dropping down couple of times in a few seconds.
There were no changes made on SmartThings nor on modem/router side before the issue start (1st September).
Situation is quite anoing because sometimes automation is running fine but when hub unexpectedly disconnect itself for a few seconds everything stop working for couple of minutes and devices got OFFLINE.
Please contact me in case you have some suggestion or fix for this issue.
Thanks in Advance
Part of the SmartThings Hub (Hub) Events:
2020-09-02 7:42:17.121 PM CEST HUB hubStatus disconnected Your SmartThings Hub at Domov is now disconnected. Please check your internet connection.
2020-09-02 7:42:17.114 PM CEST HUB hubStatus active Your SmartThings Hub at Domov is now active.
2020-09-02 7:42:17.094 PM CEST HUB hubStatus disconnected Your SmartThings Hub at Domov is now disconnected. Please check your internet connection.
2020-09-02 6:37:28.367 PM CEST HUB hubStatus active Your SmartThings Hub at Domov is now active.
2020-09-02 6:33:48.094 PM CEST HUB hubStatus disconnected Your SmartThings Hub at Domov is now disconnected. Please check your internet connection.
2020-09-02 6:32:35.437 PM CEST HUB hubStatus active Your SmartThings Hub at Domov is now active.
2020-09-02 6:30:07.086 PM CEST HUB hubStatus disconnected Your SmartThings Hub at Domov is now disconnected. Please check your internet connection.
2020-09-02 6:07:42.608 PM CEST HUB hubStatus active Your SmartThings Hub at Domov is now active.
2020-09-02 6:06:17.182 PM CEST HUB hubStatus disconnected Your SmartThings Hub at Domov is now disconnected. Please check your internet connection.
2020-09-02 6:06:17.173 PM CEST HUB hubStatus active Your SmartThings Hub at Domov is now active.
2020-09-02 6:06:17.151 PM CEST HUB hubStatus disconnected Your SmartThings Hub at Domov is now disconnected. Please check your internet connection.
2020-09-02 5:55:03.649 PM CEST HUB hubStatus active Your SmartThings Hub at Domov is now active.
2020-09-02 5:54:17.176 PM CEST HUB hubStatus disconnected Your SmartThings Hub at Domov is now disconnected. Please check your internet connection.
2020-09-02 5:54:17.168 PM CEST HUB hubStatus active Your SmartThings Hub at Domov is now active.
2020-09-02 5:54:17.156 PM CEST HUB hubStatus disconnected Your SmartThings Hub at Domov is now disconnected. Please check your internet connection.
