Hi,
I am very new to Smartthings environment so I had a lot of digging for past few weeks. The main stumbling block is that Smartthings Hub does not recognised TKB’s TZ69E as a Smart Energy Outlet thus is being treated as Switch.
I have developed a Smartapp using one of the power monitoring example in the internet and download it into the Hub. I would need to get TZ69E recognised as a smart energy outlet.
I would appreciated few pointers to get me going.
Best Regards
Shane
CSC
September 5, 2016, 12:57am
#2
Can u share the device zwave raw description from IDE? I would like to take a look.
introkun
(Sergey Gradovich)
September 8, 2016, 2:12pm
#3
How to get device raw description from IDE when device is not able to connect to the Z-Wave network?
Hi,
I am able to pair it. I got AEOTech Z-stick gen5 to get raw data when pairing. The identity is as followed.
Manufacturer id = 118
Product: type =0004, id 0002
Here below is the data which I hope will help.
Best Regards
Shane
Notify.NodeAdded
Notify.NodeProtocolInfo
Notify.ValueAdded: Node : 180 CC : 94 Type : Byte Index: 0 Inst : 1 Value: 0 Label: ZWave+ Version Help : Units:
Notify.ValueAdded: Node : 180 CC : 94 Type : Short Index: 1 Inst : 1 Value: 0 Label: InstallerIcon Help : Units:
Notify.ValueAdded: Node : 180 CC : 94 Type : Short Index: 2 Inst : 1 Value: 0 Label: UserIcon Help : Units:
Notify.ValueAdded: Node : 180 CC : 134 Type : String Index: 0 Inst : 1 Value: Unknown Label: Library Version Help : Units:
Notify.ValueAdded: Node : 180 CC : 134 Type : String Index: 1 Inst : 1 Value: Unknown Label: Protocol Version Help : Units:
Notify.ValueAdded: Node : 180 CC : 134 Type : String Index: 2 Inst : 1 Value: Unknown Label: Application Version Help : Units:
Notify.ValueAdded: Node : 180 CC : 115 Type : List Index: 0 Inst : 1 Value: Normal/-1dB/-2dB/-3dB/-4dB/-5dB/-6dB/-7dB/-8dB/-9dB/ Label: Powerlevel Help : Units: dB
Notify.ValueAdded: Node : 180 CC : 115 Type : Byte Index: 1 Inst : 1 Value: 0 Label: Timeout Help : Units: seconds
Notify.ValueAdded: Node : 180 CC : 115 Type : Button Index: 2 Inst : 1 Value: Label: Set Powerlevel Help : Units:
Notify.ValueAdded: Node : 180 CC : 115 Type : Byte Index: 3 Inst : 1 Value: 0 Label: Test Node Help : Units:
Notify.ValueAdded: Node : 180 CC : 115 Type : List Index: 4 Inst : 1 Value: Normal/-1dB/-2dB/-3dB/-4dB/-5dB/-6dB/-7dB/-8dB/-9dB/ Label: Test Powerlevel Help : Units: dB
Notify.ValueAdded: Node : 180 CC : 115 Type : Short Index: 5 Inst : 1 Value: 0 Label: Frame Count Help : Units:
Notify.ValueAdded: Node : 180 CC : 115 Type : Button Index: 6 Inst : 1 Value: Label: Test Help : Units:
Notify.ValueAdded: Node : 180 CC : 115 Type : Button Index: 7 Inst : 1 Value: Label: Report Help : Units:
Notify.ValueAdded: Node : 180 CC : 115 Type : List Index: 8 Inst : 1 Value: Failed/Success/In Progress/ Label: Test Status Help : Units:
Notify.ValueAdded: Node : 180 CC : 115 Type : Short Index: 9 Inst : 1 Value: 0 Label: Acked Frames Help : Units:
Notify.ValueAdded: Node : 180 CC : 50 Type : Decimal Index: 0 Inst : 1 Value: 0.0 Label: Unknown Help : Units:
Notify.ValueAdded: Node : 180 CC : 37 Type : Bool Index: 0 Inst : 1 Value: False Label: Switch Help : Units:
Notify.ValueAdded: Node : 180 CC : 39 Type : List Index: 0 Inst : 1 Value: Disabled/Off Enabled/On Enabled/On and Off Enabled/ Label: Switch All Help : Units:
Notify.NodeNaming
Notify.ValueChanged: Node : 180 CC : 94 Type : Byte Index: 0 Inst : 1 Value: 1 Label: ZWave+ Version Help : Units:
Notify.ValueChanged: Node : 180 CC : 94 Type : Short Index: 1 Inst : 1 Value: 1793 Label: InstallerIcon Help : Units:
Notify.ValueChanged: Node : 180 CC : 94 Type : Short Index: 2 Inst : 1 Value: 1792 Label: UserIcon Help : Units:
Notify.EssentialNodeQueriesComplete
Notify.ValueAdded: Node : 180 CC : 50 Type : Decimal Index: 8 Inst : 1 Value: 0.0 Label: Power Help : Units: W
Notify.ValueAdded: Node : 180 CC : 50 Type : Decimal Index: 16 Inst : 1 Value: 0.0 Label: Voltage Help : Units: V
Notify.ValueAdded: Node : 180 CC : 50 Type : Decimal Index: 20 Inst : 1 Value: 0.0 Label: Current Help : Units: A
Notify.ValueAdded: Node : 180 CC : 50 Type : Decimal Index: 24 Inst : 1 Value: 0.0 Label: Power Factor Help : Units: Power Factor
Notify.ValueAdded: Node : 180 CC : 50 Type : Bool Index: 32 Inst : 1 Value: False Label: Exporting Help : Units:
Notify.ValueAdded: Node : 180 CC : 50 Type : Button Index: 33 Inst : 1 Value: Label: Reset Help : Units:
Notify.ValueChanged: Node : 180 CC : 134 Type : String Index: 0 Inst : 1 Value: 3 Label: Library Version Help : Units:
Notify.ValueChanged: Node : 180 CC : 134 Type : String Index: 1 Inst : 1 Value: 4.05 Label: Protocol Version Help : Units:
Notify.ValueChanged: Node : 180 CC : 134 Type : String Index: 2 Inst : 1 Value: 2.51 Label: Application Version Help : Units:
Notify.Group
Notify.Group
Notify.ValueChanged: Node : 180 CC : 39 Type : List Index: 0 Inst : 1 Value: Disabled/Off Enabled/On Enabled/On and Off Enabled/ Label: Switch All Help : Units:
Notify.ValueChanged: Node : 180 CC : 115 Type : List Index: 0 Inst : 1 Value: Normal/-1dB/-2dB/-3dB/-4dB/-5dB/-6dB/-7dB/-8dB/-9dB/ Label: Powerlevel Help : Units: dB
Notify.ValueChanged: Node : 180 CC : 115 Type : Byte Index: 1 Inst : 1 Value: 0 Label: Timeout Help : Units: seconds
Notify.ValueChanged: Node : 180 CC : 37 Type : Bool Index: 0 Inst : 1 Value: False Label: Switch Help : Units:
Notify.ValueChanged: Node : 180 CC : 50 Type : Bool Index: 32 Inst : 1 Value: False Label: Exporting Help : Units:
Notify.ValueChanged: Node : 180 CC : 50 Type : Decimal Index: 0 Inst : 1 Value: 0.000 Label: Energy Help : Units: kWh
Notify.ValueChanged: Node : 180 CC : 50 Type : Decimal Index: 8 Inst : 1 Value: 0.0 Label: Power Help : Units: W
Notify.ValueChanged: Node : 180 CC : 50 Type : Decimal Index: 16 Inst : 1 Value: 0.0 Label: Voltage Help : Units: V
Notify.ValueChanged: Node : 180 CC : 50 Type : Decimal Index: 20 Inst : 1 Value: 0.000 Label: Current Help : Units: A
Notify.NodeQueriesComplete
Notify.ValueChanged: Node : 180 CC : 50 Type : Decimal Index: 24 Inst : 1 Value: 0.00 Label: Power Factor Help : Units: Power Factor
CSC
September 11, 2016, 4:58am
#6
For the TZ69, can you try with genetic zwave switch?
Mark_Elder
(Mark Elder)
December 11, 2016, 3:12pm
#7
Hi - just picking up this conversation that seems to have stalled: I have tried the generic zwave switch handler and it doesn’t show the power consumption (seems to switch on and off, most of the time - seemed to miss one command but that might have been unconnected to the handler).
