I found them on amazon.com but not .ca there goes the exchange rate and shipping killing it !
Hereās what I foundā¦
I have an iPad 3 that I want to flush mount like this. I currently have my iPads hung in 8x10 picutre frames with power behind.
I know you are using an iPad mini but I am curious how you came to the dimensions to cut the hole in the wall. How much wider and taller did you account for when cutting the hole for?
Looks like I know what Ill be doing next weekend⦠I like that MagBak mount
Just a quick comment regarding the tablet charging 100% of the time. You could utilize a GE smart things compatible plug-in and schedule it to switch off periodically. The duration of āoff timeā could be adjusted based upon battery life.
Itās likely that you could kick it on a few hours each night, but otherwise leave it off.
Hello how are you connecting the face plate to the enclosure?
Great work. What material did you use for mounting frame and exterior frame? Also, how did you attach the front frame?
