[smartthings-cli] Login samsung account without web browser
Hi,
I am a software developer and I am analyzing the smartthings-cli source code.
I have a question about login.
When I use smartthings-cli to login samsung account, My Web browser is poped.
I want to register to my Samsung account using smartthings-cli with myid and password without a web browser.
If it is supported , please explain it.
Additional info here:
You can also use a personal access token (PAT) for authentication
Hi, @leevisual. Welcome to the SmartThings Community!
Yes, as @TapioX mentioned, you can get a Personal Access Token from here: Samsung account
Note: This token is static and linked to your account, so if you’ll use more than one, you need to get a token from each account.
Then, add the config.yaml file in the corresponding path. You can have more than one “profile” so you can set one for different accounts. For example:
default:
  token: xxxx-xxxx-....
account2:
And then use the “profile” in your commands, for example:
smartthings devices --profile=account2
More info here:
