Hello,
Just bought the Bespoke AI Jetbot. When it is successfully added to ST and when you click on it it goes to blank screen and you can’t control it. Only thing I see is Device control and Service at the bottom, but all the rest is blanked.
I have two Samsung ACs, Samsung Freestyle projector, Samsung Soundbar, Philips Hue, Tuya smart, Smartthings Hub v2 all attached and all working. Only the Jetbot isn’t.
I’ve done the usual stuff like reboot, reconnrect, clear cache, data, etc. Tried it all, no success.
The same thing happened with the two ACs and couldn’t use them through ST for 2 years. After the last update they work, but the Jetbot isn’t.
I created a new samsung account and added the Jetbot - there it DOES work.
However on my original account, it doesn’t.
Tried to troubleshoot by deleting my whole home
Started adding each appliance one by one until it breaks:
First time - it broke after adding the hub.
Second time - didn’t connect the hub, BUT it broke after creating lightning groups and adding routines to motion sensors.
Third time - I am seeking if someone had the same issues?
Workaround at the moment:
- I use all my appliances through one account
- and use the Jetbot AI through another account
I don’t want to use two accounts. I want it all under one, so I can use the automations properly.
Please advise if you ran into the same problem and found a solution.
