I have both the apps on my phone - the classic and the smartthings app.
I had installed Hub (Hub 1) a few days ago. I was able to add z-wave devices to this hub. Both my apps were able to control the devices and the hub.
A week ago, I setup another Hub (Hub 2). Hub 1 was disconnected at this time, and Hub2 became the only Hub that I can control from SmartThings app. I need to access Hub1 network settings (which I believe can be done only through SmartThings app) since I have to change the network settings.
I have gone back and deleted Hub2 from the SmartThings portal but I still can NOT access Hub1 (at least from the SmartThings app). Funnily enough Classic app still allows me to play with the devices and the Hub.
I could reset and start over, but the pain of excluding and including up all the z-wave devices gives me jitters. Can someone please help? Is this a known issue? Should I do anything differently?
I was under the impression you could only have 1 Smartthings hub connected to a given network at any one time (more than one hub allowed but not at same location).
Are you able to see your old hub in the SmartThings IDE?
