So, hadn’t seen this app tested anywhere on the Nvidia Shield TV. The Google Play store says that it’s not compatible but we all know to take that with a pinch of salt…
Works great. I don’t need no 2015/16 Samsung SmartTV! Everything works instantly. It won’t show up on the normal home screen for the Shield but you can ‘open’ the app from the ‘Apps’ menu in the settings area, not sure how much work it would take for the SmartThings team to brush up the app so it’s officially/properly supported on Android TV?
It depends on your Android TV device. If it’s on an official Android TV release, only the TV interface is available in SharpTools which doesn’t have the screen to unlock the Tasker plugin. If you’re using one of the many Android boxes that run a standard version of Android, the full interface should be available and you can use Tasker and SharpTools just like normal.
That being said, if you have an official Android TV release and you’ve gone as far as side loading Tasker, you could backup your data from SharpTools on a mobile device (where the IAP is unlocked) and restore it on your Android TV box.
