Smartthings App not showing "Power Meter"
The displays in the new app are quite disconnected from the DHs. The displays in the new app are Capability representations. Some/most Capability has a representation on the UI/UX in a way how ST defined it. If some other way, differently should be the Capabilities represented then a vid can be created. It is all disconnected from the DH in that way, that the code for any representation is not coded in the DH but on the new SmartThings API and the list of Capabilities or a defined vid in the DH code assigns what should be visible in the new app.
In your case the DH code doesn’t make any difference, it is the Capability representation which has been screwed up.
Some reference to understand how the UI is working in the new app:
