GSzabados
(Gabor Szabados)
December 6, 2020, 9:51pm
14
Thanks!
It seems to be something special is going on. There are a few similar reports as @buster ’s.
Hi, Hope everyone is well?
I’ve just purchased one of these to monitor my power consumption and feed the data into Grovesteams.
Had trouble installing it and had to use the Zwave tweaker to get the device to pair.
But now the problem I have is with the DTH. The device installs with the standard Aeon Energy Meter DTH (after changing from zwave tweaker) which does not work for the power meter and jumps to display GW with no data but does show the energy consumption
I have tried ClassicGOD DTH ( thank you for the work to create this) and this is better but still bombs out on the power meter , especially if you turn on a large draw object such as a cooker .
I’ve also tried the amend Tmp2k version of this DTH but I get worse result with no data at all then.
So question is does any one …
And
There’s some issue with the Smartthings app. After about two months of using this handler it displays the power usage and energy in “gigawatts” and “gigawatt-hours”. Is this a bug? How do i fix this?
So there is definitely a bug in the app. Must be some clever solution again, and probably who coded it has no idea what is the difference between kW, MW and GW. (Like the temperature converter was recently.)
@Brad_ST , @dckirker , @steven.green , @jody.albritton
Can one of you have a look what is causing this GigaWatt flip over on the UI?
