Smartthings App Device Data Lost: Best Path Forward?
These might be functional, but we would require a model number for each one so that we can provide you with accurate directions. Keep in mind that some of these models are quite old!
You should be fine with the Zooz stuff. Just search on the forum for the model number, and you will probably find pairing directions.
This lock should also work; again, just search the forum for directions and the required driver.
This should also work; simply search the forum.
Some devices are compatible with the stock SmartThings driver, while others require a custom Edge community driver. Stock drivers will load automatically, but custom drivers need to be added to your hub before attempting to pair the device.
Read this How to install Edge drivers and Where to find and how to install Edge device drivers
Most of what you learned about SmartThings no longer applies!
These are a few links to the more popular driver channels that you may need,
Mariano Shared Beta Driver Click Here
Taustin Edge Drivers Channel Click Here
Philh30 Edge Driver Channel
You have a lot of work ahead of you and a lot of reading to do!
